Old 11-02-2015, 10:35 AM   #41
SSDiv6
Talking Re: 2015 to 2016 NHRA Rule Changes
Originally Posted by Andrew Hill View Post
I'd love to see them drop the max of 250 lb added rule, so you could run an Opel GT.
That would be cool!
I would be like in the early day of Dave Hutchen's terrorizing Modified Eliminator with the Opel GT!
Old 11-02-2015, 10:41 AM   #42
Adger Smith
Liked 880 Times in 311 Posts
Default Re: 2015 to 2016 NHRA Rule Changes
I believe an Opal GT can and has been run in SS. Wasn't it one of the Zane Gang that ran it in SS/AX with a Buick V-6?
Adger Smith (Former SS)
Old 11-02-2015, 01:28 PM   #43
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
Originally Posted by goinbroke2 View Post
So a 73 pinto fits SS/PA at 1938# with a 104hp engine....swap that to a 151hp 73 302 with canfield heads...12.83 factor, what GT class does that fit?....GT/J? 11.05 index?
Ahh, maybe I'm reading it wrong. Wonder what a pinto with a SS 302 would run?
'73 Pinto (hatch) weighs 2202 lbs.
Adding 250 lbs maximum allowable weight to the shipping wt. now = 2452 lbs.
The min. weight in GT is 2670 so that is what the car has to weigh with driver.
The SS GT/MA index is 11.75 at 14 lbs per factored h.p.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 11-02-2015, 07:26 PM   #44
Jason
Liked 8 Times in 5 Posts
In the past it has been that cars not making the minimum (car) weight of 2500 by adding 250 lbs are not allowed to run GT. Doubt if that will change. The shipping weight of any car for SS/GT must be at least 2250 lbs or greater to begin with.
Jason is offline   Reply With Quote
Old 11-02-2015, 10:41 PM   #45
Andrew Hill
Andrew Hill's Avatar
Liked 174 Times in 39 Posts
As Jason mentioned in the post above, to run SS/GT, you have to meet the minimum shipping weight. The SS/X classes do not have that requirement (and can have full tube chassis if I read correctly), so yes you can run one in SS/X classes. I just think one would make a really cool GT car with a late model fuel injected engine, especially with the separate RWD/FWD HP ratings now.
3207 D/SA, C/ED
Andrew Hill is offline   Reply With Quote
Old 11-03-2015, 01:46 AM   #46
Adger Smith
X2 Andrew. If the old Wayne County car was still around it might work well.
Old 11-03-2015, 08:17 AM   #47
ALMACK
ALMACK's Avatar
That's what I was thinking, but since I was not certain, I did not post that the '73 Pinto Hatch is not eligible.
However....the '73 Pinto wagon is eligible for GT with a factory shipping wt. of 2378 lbs.
The oldest Pinto hatch eligible for GT is the 1974 model @ 2366 lbs. shipping wt..
I/PS '95 Mustang GT
