Old 02-14-2015, 07:53 PM   #1
Vinnie78
Default Re: 77 nova stock or s/stock st or auto Help!!!!
Tell us more about the Muncie.
No reason why you couldn't run a Muncie in T/Stock ...if it had enough low gear in it.
The transmission I have is the 252 first gear wide ratio box from a 65-67 GTO withe two groves on the input shaft . I was figuring at least 4.88 rear gear with that . What do you think ???
Vinnie78 is offline   Reply With Quote
Old 02-14-2015, 08:05 PM   #2
No..I was hoping it was an old Nash or Liberty pro shifted gear set..2.70 minimum, but better, a 2.95.
Not gonna have enough gear in the rear to offset the low gear. Not with the 305 2 bbl.
Old 02-14-2015, 11:40 PM   #3
Vinnie78
I dident think so . But I did see a set of 5.13 gears listed somewhere . Do you think it's enough ??
Old 02-15-2015, 12:14 AM   #4
Actually yes.
I figured a 92 " tire and 5.13's .
At about a second under (100 mph, give or take) you shouldn't be over 6 grand, which I think is plenty for the medium size 2bbl. on the 305.
But you need more first gear. Otherwise it'll hook and bog and kill a bunch of ET.
I don't think I'd invest in a 8.5 spool and axles for any stick car though.
Old 02-15-2015, 04:10 PM   #5
Vinnie78
I'm also concerned about the 8.5 being strong enough . What do you think of the Richmond with the 2.88 / 191 / 133/100
With the 5.13 gear . And a 92 tire I think is should get it moving with the 305 just wondering it it can pull between 2 nd and 3 rd with out falling on its face . What intake would be best for that little motor ??
Old 02-15-2015, 04:24 PM   #6
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
2.88 is better. You really need something in the 3.10-3.20 range for first gear and a 305. The 8.5 is plenty strong enough.
Old 02-15-2015, 04:42 PM   #7
Vinnie78
What about the tremec 5 speed and take out the 5th gear the way we did the 4 speeds in nascar we removed the teeth off of 1st and 2nd . It has a
3.27 1.98 1.34 1.00 . They don't really shift all that great .
