Old 11-02-2014, 10:26 PM   #1
brent flynn
brent flynn's Avatar
Default Re: Stocker Cylinder Heads....
Originally Posted by Lou Jeffery View Post
The basics of Fast stocker cylinder heads are very simple. If you consider each intake port and exhaust port assembly as a orifice you can flow them with a constant draw and establish an effective orifice size. There are endless ways to change or improve flow. The only way to significantly improve flow is to change the effective orifice size of the assembly by porting!
Stop lying to yourselves and Stop pushing NHRA to police something that is out of control. If NHRA were to throw out ALL modified stocker heads the pits would be empty. I know I know it's only the other guys that would stoop to cheating NOT YOU!
Just buy the $1000 cast iron intake and the $3500 heads and have fun like MANY others do. Louis Jeffery
Not true, Louis, my slow E/Stocker would still be there, watching tumbleweeds blow across the staging lanes, as i take a final bye run pass, and pull up to the Winner's Circle to accept my Wally... hehe
Old 11-03-2014, 01:02 PM   #2
James L Miller
Liked 25 Times in 16 Posts
I'm looking at building a "killer?" 318 2bbl combo with the 302 swirl port heads. It sounds like I can use a bowl hog and go all the way down to the valve guides as part of the valve job? Or maybe use a Serdi type cutter with a radius at the bottom of the cutter to open up the bowl as long as it's done all the way around?
When did they get rid of the .250" depth cut limitations? I guess I haven't been paying attention to the rules.
I also saw the 308 360 head was legal but needs to have the smaller 318 valves put into it. I guess with the VJ changes that opens up another possibility with new seats and whatever VJ works. It may not make much difference with the tiny BBD 2bbl carb?
Mopar 2 Ya!
Old 11-26-2015, 11:51 AM   #3
Billy Nees
Liked 7,771 Times in 1,741 Posts
You just may find that when dealing with seriously restricted combos(I think that a 2V 318 qualifies even though that carb flows more than what I'm used to) you might want to be looking for the smallest runners. Velocity is your friend not necessarily volume. The manufacturers didn't spend lots of time and money coming up with those swirl port heads just as an engineering exercise.
Billy Nees 1188 STK, SS
Old 11-26-2015, 12:50 PM   #4
Lee Valentine
Liked 319 Times in 68 Posts
Well said Billy.
Lee Valentine 1661 STK
Old 11-26-2015, 01:40 PM   #5
James L Miller
Thanks for the advice Billy. Sometimes I wonder if the engineers cared about airflow in the 1950s and 1960s on most engines. I guess the emissions and CAFE standards forced the auto makers to make them more efficient in the 1980s and later. I'm thinking the 273 4bbl combo looks more attractive, basically the same 302 head casting. The 308 head isn't legal on the 273 but is on a 318. Sort of odd, but the 340 intake is legal for the 273 4bbl and apparently so is the old Edelbrock LD4B intake. Maybe that got in via the 1966 D/Dart engine? Now I wish I had that LD4B I bought in 1975 and gave to a friend in the 1980s.
Mopar 2 Ya!
Old 11-30-2015, 07:25 PM   #6
65signet
Liked 49 Times in 22 Posts
The 340 intake is not legal, you must use the LD4B with the right part number on it.
65signet is offline   Reply With Quote
Old 11-03-2014, 01:15 PM   #7
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
You would have me there to race Brent.
Rich Taylor
I/SA - 321
Old 11-26-2015, 10:34 AM   #8
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Had to revive this post.
It was interesting and no jabs taken.
Saw a web site on a S/SS head machinist named Tommy Sizemore.
Then checked his references on Internet.
Is this guy good or not?
Old 11-26-2015, 11:16 AM   #9
Adger Smith
Liked 880 Times in 311 Posts
Dan,
Define "Good"
He could be called a real "Pillar of Power"
Adger Smith (Former SS)
Old 11-26-2015, 01:57 PM   #10
Dan Fahey
Dan Fahey's Avatar
Originally Posted by Adger Smith View Post
Dan,
Define "Good"
Cannot reach him since October.
He has a pair of my heads getting updated.
Tommy Sizemore seems to have fallen of the face of the earth.
D
