#1 | |
Not true, Louis, my slow E/Stocker would still be there, watching tumbleweeds blow across the staging lanes, as i take a final bye run pass, and pull up to the Winner's Circle to accept my Wally... hehe
1968 Bird/TRW 455/Home ported 13's, '70 Qjet,Holley Street Dominator manifold, Comp Solid FT, 10.817/122.30/1.440 Workin' on E/SA combo ![]() |
Liked 25 Times in 16 Posts
I'm looking at building a "killer?" 318 2bbl combo with the 302 swirl port heads. It sounds like I can use a bowl hog and go all the way down to the valve guides as part of the valve job? Or maybe use a Serdi type cutter with a radius at the bottom of the cutter to open up the bowl as long as it's done all the way around?
When did they get rid of the .250" depth cut limitations? I guess I haven't been paying attention to the rules. I also saw the 308 360 head was legal but needs to have the smaller 318 valves put into it. I guess with the VJ changes that opens up another possibility with new seats and whatever VJ works. It may not make much difference with the tiny BBD 2bbl carb?
Mopar 2 Ya! |
#3 | |
Liked 7,762 Times in 1,741 Posts
Liked 319 Times in 68 Posts
Well said Billy.
Lee Valentine 1661 STK |
#5 | |
Mopar 2 Ya! |
#6 | |
Liked 49 Times in 22 Posts
The 340 intake is not legal, you must use the LD4B with the right part number on it. |
#7 | |
Liked 33 Times in 16 Posts
Rich Taylor I/SA - 321 |
Liked 184 Times in 113 Posts
Had to revive this post.
It was interesting and no jabs taken. Saw a web site on a S/SS head machinist named Tommy Sizemore. Then checked his references on Internet. Is this guy good or not? |
Liked 880 Times in 311 Posts
Dan,
Define "Good" He could be called a real "Pillar of Power"
Adger Smith (Former SS) Last edited by Adger Smith; 11-26-2015 at 11:16 AM. Reason: sp |
