Old 11-02-2014, 04:24 PM   #11
D.Johns
D.Johns's Avatar
Liked 18 Times in 6 Posts
Default Re: Stick Dime Rockets
In Scott's car with the liberty T-5 class required a diaphram style clutch. Used a solid hub, no marcel springs and made to a certain thickness as well as a pressure plate made for a certain amount of force to be applied. Would shim the pressure plate until we received the slippage that we wanted based on the torque gauge that he made and calculated force he wanted to apply. Car is a NA modular 4.6 which means low torque but good HP. Car weighs 3200+ with 5.13 rear gears on a 26*10.5 launch at 7k+
It was hard to get that car to go through the clutch without puckering up the disc after 2-3 passes. Not enough slippage and it would pull the engine RPM down. On a small tire car it's easy to get up on the wheel speed. There were others in the class that the best we can figure is using a sintered iron disc instead because they were able to slip the clutch way more then us without spitting out clutch discs every pass.
IMO sintered iron and slipping the clutch in a controlled fashion(ie not the drivers foot) to control the RPM, tire strike and wheel speed is the only way to go in a serious stick car. However on the budget that may not be an option. Then it will be a controlled spin with the tire and let the engine do the work with a broad trq/power curve.
2014 Cobra Jet FS/XX #3345 STK/SS
Like us on http://www.facebook.com/pages/Daniel...25886327426822
D.Johns is offline   Reply With Quote
