Old 09-08-2014, 07:35 PM   #7
SS Engine Guy
Default Re: Stock Suggestion # 1
Ok, here is the edit for easy understanding. Fix the problem.
- problem: factory experimental cars being placed in Stock and S/S
- solution: place them where they actually belong which Is Comp in some cases and SS in others. And even when placed in SS they will have to be factored with in reason.
- clarification on factoring: if you took a 427 Chev. running legal under current super stock rules and added a much better race only head, 14-15 to 1 compression, 1000 cfm of pure airflow(not air and fuel), fuel and timing control in milliseconds. Surely it wouldn't be rated the same or lower than before those add ons.
SS Engine Guy is offline   Reply With Quote
