Liked 53 Times in 16 Posts
This is for GTX John- you mention tearing up more psrts on your wagon because i can assume it is heavier- I am building a 65 Impala, racing weight will be between 3900-4100 lbs, like the 68 Impala I ran in I/S I never broke any parts, really! I ran a Jerico stick too- I will be running a Turbo 350 in my 65 with the same 396/325HP combo- can I expect breakage because of the tranny? Just wondering-
Will Lamprecht- 65 Impala in progress Div 1 -I/SA |
Liked 2,487 Times in 698 Posts
I am afraid probably so...........
Particularly if it is fairly fast ( 1.498 to 1.54 60's ) Jon 's wagon P/SA = 3850 O/SA= 3620 Small Valve Low Po 318 = 230 HP with 380 Lift Mark William's 35 Spline/Axles/Pro Gears In Phoenix this year .....Broke 9 Teeth off Ring Gear Bent 8 3/4 like a pretzel Took an hour to get each axle out with slide hammer with 300 Lb Guy on the end. Your results may vary.
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 04-16-2014 at 10:53 PM. |
#3 | |
Liked 101 Times in 52 Posts
Next time you over achieve show us some pictures please! |
#4 | |
Liked 460 Times in 91 Posts
Bob Bender 144 O/SA 2010-2012 National Record Holder |
