Old 03-08-2014, 10:19 AM   #19
V M Kauffman
Default Re: Kestrel weather station
How do you measure Oxygen do you have a sensor? I have used a Oxygen Meter since 1985. % of oxygen has a big affect on performance! a change from 19.8% to 19.5 is big!
Originally Posted by Altronics View Post
PerformAIRE weather stations are the only patented system that has a Density Altitude calculation specific for determining horse power in an internal combustion engine. It is critical to measure the amount of oxygen and the amount of water in a sample of air in order to determine correctly how it will effect the change in horsepower.
Systems that are designed for hiking, aviation, sailing, etc that are not licensed by Altronics can only calculate "text book" Density that will not always correctly relate to horsepower changes. Although it may seem ok under minimal or similar changes in atmosphere it will prove inaccurate as conditions change.
We win or lose now days by +/-0.01 seconds or less!!
With over 20 years experience in predicting your car and tech support 7 days a week!
Check out PerformAIRE Pocket unit for $289 plus Class racer discount. Click on banner above
V M Kauffman is offline   Reply With Quote
