Old 12-13-2013, 04:15 PM   #1
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
Default 351C questions
Valve seats.....when installing new seats can you blend in the ridge in the casting at the bottom of the seat?
Is the Quick Fuel SSR-780-VS an acceptable replacement for the D0ZF 9310-Z Holley 4653?
Can an adjuster be installed on the pushrod side of the rocker arm
Can floor mounted clutch linkage be installed?
Can the block be machined for 42/46 lifter phasing?
Thanks
Bill Diehl is offline   Reply With Quote
