Old 10-21-2013, 02:01 PM   #1
Stephen & Horace Johnson
Liked 163 Times in 53 Posts
Default Re: New guy here from NW Indiana
Originally Posted by stick shift coupe View Post
unlimited shortblock except for flattop pistons, solid roller cam up to .550 lift, any manual transmission allowed as long as shifts are clutch assisted etc..... the way the car is currently, is with a 308 cui small block ford, hyd roller cam, promotion prepped tremec tko600, 5.14 gear, 26x10 stiffwall tires, full tubular front suspension setup with coilovers. car has run a best of 10.41 @ 129.9 mph
you used to run Mean Street?
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
