#51 | |
If there's no advantage to EFI's over carburetors, then how come small block EFI engines are the performance equal to carbureted big blocks? Moreover, how come all production vehicles come with computers and no longer carburetors? They're more efficient in extracting more power from the same (or less) amounts of fuel. My EFI '04 Colorado does a better job with only 5cyl's of towing my Cavalier around (on less fuel I might add), than my '77 half ton 350 V8 carbureted Chevy Full Sized truck did back in '99 (it also was rated 45hp more). I'm not going to challenge your mechanical knowledge, but EFI put carbs in production vehicles to RIP status, thus proving the merit of what I stated as well...
Gary Hampton '86 Z24,173 V6 CF/S #5824 (#78 in 2021) |
#52 | |
Liked 30 Times in 17 Posts
Power is about airflow and the amount of fuel and oxygen you can combine in the chamber. IMO, a properly tuned carburetor can handle the task just as well as injectors assuming the airflow is not compromised. I have not seen significant gains by replacing a GOOD carb with a throttle body and electronic injection as far as full throttle performance is concerned. Where the injector really has an advantage is that it allows for a wider range of intake manifold design and throttle placement. If you notice the fast small blocks you refer to have a lot of technology in the cylinder heads and intake manifold that compliment the injection system. Tracy |
#53 |
Liked 534 Times in 143 Posts
Plus, if you sell your soul then anything is possible.
#54 | |
#55 | |
Liked 18 Times in 6 Posts
I remember reading some articles headlines. "The end of the Hot Rod era, Fuel injection." I remember reading about all the guys ripping off the EFI systems in 86 Mustangs to back to the tried and true Carb/manifolds and was making more power(in fact the 85 car was rated at 210hp and the 86 was 200). In fact there are still guys pulling EFI off their race cars to switch to carbs and are picking up ET. The 86-88(except for the 88 California cars) were all speed density and couldn't compensate for agressive heads, cams and intakes. The mass air cars helped out and guys learning the "new" way of hot rodding started to catch on. This is really were metered FI injection really comes into its own. You can run more aggressive on things and not lose the street ability of a daily driver at idle and part throttle driving. Computers can advance/retard cams, change timing and fuel based on air mass and O2 readings, pull timing in cases of knock or detonation. The intakes can be made in multiple configurations without having to be locked into a general design(although I've seen some mighty creative carb set ups). The new cars(talking street cars) are making a lot of power out of smaller displacement engines for a multiple of reasons. Such as better materials, better manufacturing abilities and being able to run at tighter tolerances. They can run more aggressive cam profiles, thinner ring packages, have computers to map all variables and not to mention all the hot rodders experience on how to build a better engine. On the street EFI is king for superior drivability. On the race track everyone has their own preference. I personally prefer EFI.
2014 Cobra Jet FS/XX #3345 STK/SS Like us on http://www.facebook.com/pages/Daniel...25886327426822 |
#56 |
To answer one of your questions Gary, some of the reasons late EFI engines make more power than older engines are the cylinder heads. Improved air flow and improved detonation control allowing higher compression ratios on low octane fuel with out detonation.
The '96 / '00 Vortec trucks heads are so popular on older engines that Edelbrock makes a 4 bl carb intake manifold for them. The ports are high enough a regular carb intake doesn't even cover them. You understand what raised intake ports do, right? :-) Those Vortec heads make more power than earlier (even "camel hump") heads. The reason for EFI in late model vehicles is simply emissions and fuel economy.
Ed Wright 4156 SS/JA |
#57 | |
Liked 1,070 Times in 378 Posts
Our current EFI combo was first dynoed with the carb and intake off of our current carb combo. (750 q-jet and victor -E). After breaking it in we put the big stuff EFI system and related hardware on.....It lost 15 HP... The reason is the little throttle body that comes on our combo. If we were bracket racers and could change the throttle body , then the power would swing over to a plus for the EFI. But like you say ...Its all about airflow (and of course, compression ). Being able to manipulate all the fuel and spark management gives the engine's a wake up call, but how much varies widely from engine to engine depending how out in left field you were in the first place.
Jeff Niceswanger 3740 SS Last edited by Jeff Niceswanger; 06-06-2013 at 08:49 AM. |
#58 |
Hi Jeff, I have seen that before. I would have mentioned this, but nobody would have believed me. The carb guys just know there is magic in that ECU. LOL
