Old 03-18-2013, 03:19 PM   #1
randall502
Default Re: how to speed up my pure stock 305 Camaro
I put a 3.42 rear gear and a posi unit
randall502 is offline   Reply With Quote
Old 03-18-2013, 03:34 PM   #2
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Add 4.10's
Old 03-19-2013, 01:51 PM   #3
Chris1529
Liked 70 Times in 29 Posts
I would go with at least a 4:10 or 4:30. With the OD trans, those gears would be fine unless you plans to drive long distances on the street. your 3:42 is not nearly enough gear for the strip.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 03-20-2013, 03:26 PM   #4
Dan Fahey
Dan Fahey's Avatar
On my 95 Impala SS
It uses a 4.10 with 26 inch tall tires for racing.
Change to near 28 inch tall street tires to drive home on.
With the 4L60E tranny get near 20 mpg cruising home.
If you Trailer 4.56 with 28 inch tall slick works.
D
Old 03-20-2013, 04:43 PM   #5
ALMACK
ALMACK's Avatar
Liked 369 Times in 127 Posts
^^ Good suggestions so far.
-160 deg. thermostat
- as deep of a rear gear as resonable to cruise on the road with
- minimum weight to fit class
- lots of air pressure in the front tires
- short belt to bypass the power steering (or remove PS altogether)
- aftermarket headers and an x pipe (must run mufflers that are not "see through"
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 03-20-2013, 05:49 PM   #6
Terry Witzel
Terry Witzel's Avatar
Liked 50 Times in 28 Posts
What e.t.'s are you running now? What horsepower is your motor?
Old 03-20-2013, 08:04 PM   #7
Ed Wright
Ed Wright's Avatar
Don't think it needs a chip? Many of those have a delay before the ECM goes into Power Enrichment. That is like your Holley power valve not opening for a few seconds.
You can not band aid around that. Also timing it foot braking from a low RPM. Turn the distributor far enough to make them leave like that, and it's over-advanced at higher RPM. You have to change the curve.
Just the washer part of a thermostat would be better than a 160. Do you race your car at 160? Probably not if it has an iron block.
Ed Wright 4156 SS/JA
Old 03-20-2013, 09:04 PM   #8
ALMACK
ALMACK's Avatar
160 in the burnout box.
170 when the car is fully staged.
180 at the end of the run.
all on 93 Unleaded
I/PS '95 Mustang GT
Old 03-20-2013, 08:19 PM   #9
randall502
Headers are on the way. Ordered some headman headers and got some flowmasters to go on it.
Old 03-20-2013, 08:23 PM   #10
randall502
The car has run a best of 9.72. But other than that one time it runs 9.85s. and it is a 170HP 305
