Old 02-23-2013, 02:03 PM   #1
pontiacchuck
Default Re: turbo 350
what code should i look for thank you chuck
pontiacchuck is offline   Reply With Quote
Old 02-23-2013, 06:22 PM   #2
art leong
Chuck if you are talking about a turbocharged car. I would be careful of the lightweight tricks. Many things that are done to fairly high power V8's won't stand the rapid torque of a quick spooling turbo.
Art Leong 2095 SS
Old 02-23-2013, 11:19 PM   #3
Liked 5,125 Times in 1,953 Posts
Like I was saying..It doesn't much matter..The later ones had more Torrington bearings .
If I was going to build a good one, I'd use parts from a T350 , T 250, and a 700R4 anyway
Depends on the application how many clutches you need ,where.
Can't help you any further without that.
Old 02-24-2013, 09:33 AM   #4
pontiacchuck
et bracket car 80 pontiac grand prix 455 pontiac mild built 9 in ford rear end 3:70 gears 3200 with driver 3000 stall
Old 02-24-2013, 12:54 PM   #5
In that case ,I'd build a 350C , 9 or 10 " conv. with a lock up clutch in it, 3.55 gears.
No need for the 700 and 250 parts...You can put and extra clutch in the direct if it makes you happy.
Full feed the direct drum, raise the pressure A LITTLE , hardened intermediate sprag race, (a must have), block the accumulators and the low gear blow off valve, drill a out few holes in the separator plate, and you got it.
