Liked 174 Times in 39 Posts
It's exactly the same as the engine in the GTO (and Corvette) rated at 340.
3207 D/SA, C/ED |
Liked 2 Times in 2 Posts
Countrypuppy,
Your argument does not hold water. If hitting the breaks gives you more mph then tell me the trick to run almost -1.00 and killing 20mph, do you drop the laundry and let the shoot do the work??? Car#-Driver(Opp'nt)-RT-----ET---Speed-----Car#-Driver(Opp'nt)-RT----ET---Speed 3578 Chris Mattingly 1 Joe Santangelo C2 ****WINNER**** 0.035 10.304 128.66 0.002 10.541 124.65 C/SA Index: 11.40 (+/-): -1.096 C/SA Index: 11.40 (+/-): -0.859 Prior rounds: C1 (P Boster ) 0.041 10.482 115.35 (D J Raiser ) 0.033 10.598 123.69 Qualified: #21 10.513 NS #99 No Time Car#- Driver(Opp'nt)-RT-----ET---Speed-----Car#-Driver(Opp'nt)-RT----ET---Speed 3578 Chris Mattingly Bye C3 ****WINNER**** 0.052 10.433 111.81 C/SA Index: 11.40 (+/-): -0.967 Prior rounds: C2 (J Santangelo) 0.035 10.304 128.66 C1 (P Boster ) 0.041 10.482 115.35 Qualified: #21 10.513 NS Bye
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
If you hit the brakes right at the finish line, the nose will drop and break the beam, shortening the time between the mph cone and the finish line. If you do it right at the end, you won't be on the brakes long enough to kill more than a thousandth or two and the overhang more than makes up for it.
3207 D/SA, C/ED |
Andrew I understand what you guys are talking about but his runs look like this
10:253@132.06 -1.147 10:304@128.66 -1.096 10.433@111.81 -0.967 on this pass he killed 20mph and still runs basically -1. under I think an extra 100# will be ok. And this wasn't even the car that ran the -1.20 under.
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 Last edited by 69Cobra; 09-25-2012 at 12:56 PM. |
#5 | |
4878 SS/GA 66CHEVY II |
Liked 228 Times in 70 Posts
Kris,
For the record I didn't say they won't be OK, but the other 100 LS1 cars that were all probably atleast .15 or more slower than them it makes a big difference. Oh, and I never saw you on a qualifying sheet anywhere, so I would appreciate if you back off your keyboard a little bit. Also, he didn't kill 20 mph on the 43 run because the actual mph would probably be around 128-129 as he went 128 on the 30 pass. Also, Kris it appears he shut off at the 1000ft which usually kills around .13-.15. That's how you kill about 17 mph. However, to kill 17mph by shutting off at the 1000ft and still go -.96 you have to be able to run about -1.09-1.11.
Jimmy "Cooter" Hidalgo, Jr. 4865 E/SA '04 GTO 4865 SS/GA '99 Firebird Last edited by countrypuppy4865; 09-25-2012 at 01:47 PM. |
#7 | |
#8 | |
