That would be a way to try to turn the win light on in a very close heads up.
Ed Wright 4156 SS/JA |
Liked 229 Times in 71 Posts
Mickey same rules apply if the car is low enough to trip the beams while in the throttle and if its very close a little bump in the track could easily make it trip. Also if you want to make people talk like on here all you have to do is dip the nose and you can cause mass hysteria on class racer bc people really believe a firebird/camaro C car went 132mph at that et without tripping nose or spraying nos. Also, while this "shot heard around the world" took place a 396 outran a pretty good LS1 in Dallas. So, for all of you that think its so easy to make an LS1 go -1.20, I invite you to try because I only know a couple that USED to be able to go that fast!
Jimmy "Cooter" Hidalgo, Jr. 4865 E/SA '04 GTO 4865 SS/GA '99 Firebird Last edited by countrypuppy4865; 09-25-2012 at 10:33 AM. |
#5 | |
#6 | |
Liked 534 Times in 143 Posts
The HP has been posted. I looked at it and now realized that the Ram Air LS1 Firebird Formulas are now a natural CC/SA car. They cannot get to B/SA without being a Trans Am and the different deck lid.
Edited to add: The flat hood Formula is a natural B. Last edited by KRatcliff; 09-25-2012 at 11:45 AM. Reason: Plus the flat hood. |
Kyle, I am pretty sure Trans Am came with both deck lids. It may be the non WS6 trans ams, but I have seen them both ways. They actually had plenty Trans ams that came with the flat hood as well.
Liked 282 Times in 103 Posts
Horsepower adjustments following the Jegs SportNationals
As the result of runs under the Automatic Horsepower Factoring System (AHFS) 1.20-second under policy at the Jegs SportNationals, the following change has been made. The horsepower rating for 1999-2002 GM Camaro/Firebird, entries with the 346 cubic inch engine and a factory rating of 320-325 currently rated at 369 has been increased by twelve horsepower, to 381 horsepower; for Stock Eliminator NHRA's 2012 Automatic Horsepower Factoring System outlines that any run of 1.20-second or more under the index will receive an immediate index decrease or horsepower increase. These changes are effective Sep. 24, 2012. Is that basically the same engine as what is in a 2004 GTO in E/SA rated at 340? |
Liked 174 Times in 39 Posts
It's exactly the same as the engine in the GTO (and Corvette) rated at 340.
3207 D/SA, C/ED |
