Old 09-13-2012, 01:35 AM   #1
art leong
Default Re: No AFHS for National Open @gainsville
It is a national open with record runs. I believe there will be no normal AHFS but if you go more than 1.199 under you will get the instant hit. Whether you set a record or not.
Art Leong 2095 SS
Old 09-13-2012, 03:22 AM   #2
RULER
Liked 58 Times in 18 Posts
Wink Re: No AFHS for National Open @gainsville
No vote nessary, that is the way all national opens are run, no HP unless you go 1.20 under then you get the instant hit on monday or tuesday the next week! some combo's still need that block of wood under the pedal
RULER is offline   Reply With Quote
Old 09-13-2012, 07:30 AM   #3
Chad Rhodes
Those of us that got the email from Mike Crutchfield........ It says NO AHFS, none zip, nada, take the lead out and and bomb the record 1.20 under be damned.
Chad Rhodes 2113 I/SA
Old 09-13-2012, 09:22 AM   #4
Bruce Noland
Liked 444 Times in 145 Posts
They may be saying the ahfs is not in play, but I would be very surprised if they will let a -1.20 run slide.
Bruce Noland 1788 STK
Old 09-13-2012, 10:06 AM   #5
Ed Wright
Ed Wright's Avatar
I don't think a 1.2 under run should slide. If you can run 1.2 under you do need some HP.
Ed Wright 4156 SS/JA
Old 09-13-2012, 11:37 AM   #6
Randall Klein
Liked 316 Times in 67 Posts
1.20 under used to be 1.50 under, it just doesn't sound so far under. Looking at the original Final Qualifying in SS at Indy, the whole field was 1.+ under taking into account the .30 NHRA took off.....who'da thunk? #128 Joe Tueton was 1.022 under with the previous indexes.
With the old mind set of indexes, I think no one would argue that 1.50 under (anywhere, anytime) was deserving of a hit.
Old 09-13-2012, 12:29 PM   #7
K Stubbs
Liked 20 Times in 3 Posts
When is this race? I would definately go if we can run more than 1.20 under and not get hit, just to set the record.
K Stubbs is offline   Reply With Quote
Old 09-13-2012, 12:47 PM   #8
Superfan1
Superfan1's Avatar
Liked 2,637 Times in 440 Posts
Smile Re: No AFHS for National Open @gainsville
Since there appears to be quite a bit of confusion and uncertainty about the AHFS for this race; I would think that Mike Crutchfield is the person that can clear this up.
Bill Seabrooks - superfan1
Bridgeport, CT
