Liked 1,031 Times in 368 Posts
I am pretty sure I found it. One of the brushes was shot and not hitting the rotor all the way around .There was a spot about an inch long where it appeared to have not been hitting for a while. I took a scribe and pushed the brush up into the holder a little bit and it just stayed there,not returning. Rich, when I checked wires # 1 and 10 and got that 24 ohms, I made the mistake of not rotating the unit 360 degrees to be sure it was hitting everywhere. Amateurs mistake....I rechecked it, and it came and went severely. Onan in Columbus has the brushes and springs in stock, and We will pick them up and get this thing back together tomorrow, Thanks for all the help guys
Jeff Niceswanger 3740 SS |
Liked 544 Times in 213 Posts
Bad contact between the brushes and slip rings is one of the biggest things that can cause an issue like you have Jeff. If the brush does not contact the slip ring it will arc for a while and the arcing damages the surface of the copper......Clean it with some shop roll paper untill it is as clean as you can get it.
I have been working on a Miller 300 D Trailblazer-Diesel welder. Already have hours and hours in it, changed the rotor and PC control board.....and the board was already replaced once 6 months ago.....Weld output is intermittent at best.......I spent a good part of today trying to nail down the problem and find nothing that is clearly wrong.....but it doesn't work and I already have a pile of money in parts in it and a pile of time..... Working with machines that produce electricity can be very very difficult....even for people that do it all the time like myself.... Hopefully you found your problem.....
Well Well Well
Spoke too soon, I thought I had it fixed, but now it sets a different code, and still won't run without holding in start button. I now have hertz( 61 while holding button down)). I even have 14-20hz while the motor is being cranked, but I get a code 32. Low hertz while being cranked or something like that.Went ahead and PM'ed it while it was out. Plug, fuel filter, oil etc...I stuck it back in the back of the mini van and I going to take it to the dealer Monday. I checked everything I can think of, Stator/field ohms out (@35) perfect, brushes/rotor are 21 ohms. I have cleaned and tightened grounds and checked pins till I have had enough of it. I even stuck the old controller board back into be sure .. Same 32 code... I'll let you know what they find out.....
Jeff Niceswanger 3740 SS Last edited by Jeff Niceswanger; 08-11-2012 at 09:55 PM. |
I already said that but have to repeat it..... Trust me when I tell you I have been there and done that as the saying goes.... I worked on a buddies 4KY earlier this year at home for the better part of a week at night after work.....I was just about to throw in the towel and than gave it another try.....Got it fixed and he is still using it now....probably today as there is a big race at Atco...... That code is a bit odd....Stators can test ok with an ohmeter and still cause problems.....Ohm testiing is not conclusive and I deal with this all the time.. Hopefully you found a place that can get it fixed for you...
Liked 6 Times in 5 Posts
how about a code 47 on a 5500- marqie
Code 47
Points to the ignition coils and wiring between them and the controller. The coils are magneto style.....they make spark anytime the blower wheel passes them. They are grounded by the controller thru a small wire attached on the coil. Code 47 says the controller is not connected to the coils. My experience tells me this is likely not the problem...and getting to the coils is a major job as the unit has to be completely disassembled.... I would check the white wires going down to the coils. They both have a connector on the upper section side. The controllers on these machines fail a lot.......That is more likely the problem.... It is a PC board in a holder/tray located inside the box where the start/stop is.....One weatherpak style connector......Those connectors can also cause problems....
Well today I removed a CMM 7000 EFI unit for random shutdowns.
Bench tested it under load untill it failed... Showed a Code 47 fault. Did it more than once. I checked the coil connections to the controller and all was fine as it always is... Installed a NEW 300-5047 Controller and continued to test the unit... Ran the rest of the day on and off with various loads applied and no more shutdowns... So for the umpteenth time a controller is at fault and the fault code it showed was somewhat misleading..... And during the time I worked on this unit another customer came in with a similar problem......He may or may not be getting a controller also but he opted for a wait and see deal as we cleaned some wire connections.... My money is on him returning before the week is out to get the controller replaced.....and regretting not doing it today.......
#8 | |
Took this to 2 different dealers. Both said the Stator was shot and wanted 1300 by one dealer and 2000 by the other. Cummins Bridgeway in Columbus sold us a complete new one for 2550. I guess I have a bunch of spare parts. This one is a model 4.0KY-FA 26100K. It looks identical to me but I'm sure some things are not interchangeable. Thanks for your help getting us through the generator blues.
Jeff thats a real good price for a new one....
I think we discussed it possibly being the stator..... I have replaced them and it's always a repair that has to be weighed out..... How old is the machine.....how many hours on it.....what kind of shape is it it....how well was it taken care of...... I think you will be good for quite a while..... I have one to work on tomorrow.....Fuel pump or fuel line issue....
Liked 135 Times in 74 Posts
Rich, not to change the subject but considering autostart for generator when coach batteries get low.
HAve you seen these and any problems. I know you only see the problems but any input would be helpful. We do some dry camping, do not like to keep generator running if I do not have too. |
