Old 07-11-2012, 10:11 PM   #1
jmarkaudio
Default Re: Loose booster in dominator
Originally Posted by Dave Jung View Post
Thanks for responding. Why would they be missing? Would someone take them out or do they not come from the factory with them? Who is BLP?
Not sure why it came out, most you have to use significant force to pull out. I have seen one run without the booster pin, not a good thing to do though. I converted a carb to E85 for someone, and when we took the borrowed carb off and turned it over to drain the fuel the booster came out...
BLP.
http://blp.com/cart/index.php?main_p...roducts_id=372
jmarkaudio is offline   Reply With Quote
