Liked 5 Times in 5 Posts
thanks for the responses guys. Quick update, I dissassembled the carb and there was no tube through the main body holding the booster in place on any of them. I then took a small auto center punch and carefully punched a series of them in the booster and the carb body where it presses in. I then tapped the booster in place and it is good as new.
Dave
6535 stk 81 Malibu K/SA |
They need to have booster pins/ booster stake tubes in them. You can get them from BLP, ask for the .160 ID pins, they are not expensive. I use a 1/4 brass punch to drive them in. You really need them, they set the passage diameter to the booster. It will run without them, but not as well.
Thanks for responding. Why would they be missing? Would someone take them out or do they not come from the factory with them? Who is BLP?
You can't run that carb on the stocker Dave
2009 V/SA Record Holder |
#5 | |
BLP. http://blp.com/cart/index.php?main_p...roducts_id=372 |
