Old 05-04-2012, 02:53 PM   #1
Robert Simpson
Liked 20 Times in 12 Posts
Question Re: Aftermarket Rack & Pinion
Bobby I'm with you on this. I like keeping things as stock or super stock as possiable. But, on the flip side, have you seen what is allowed to be done with a FWD conversion car to run GT or Modified? I do see the rack an pinions steering on those, because they came with it. But, to allow, round tube lower frame rails on the front with tube A-arms? But if you have a RWD car in GT or what ever you can't run tube A-arms? Or rack and pinion location in relation to the cross member, Weird. To go back to your question I know of several SS/AH racers who have asked about using rack and pinions in there cars. I was told they were told NO, period! Crazy... I say if it could be a bolt on unit then yes.
Robert Simpson is offline   Reply With Quote
Old 05-04-2012, 03:03 PM   #2
NWDragracing
Default Re: Aftermarket Rack & Pinion
Yep, the FWD cars have the freedom to use a manufactured or fabricated crossmember and lower control arms when the RWD are not allowed. The aftermarket has some good pieces available from BMR, AJR, QA1 and others for RWD cars that probably would make them safer than the old OEM parts that may eventually need repairs or replacement.
If it was allowed on RWD, you could also expect some of the ADRL, NMCA and NMRA cars cross over and race in some of the NHRA classes.
NWDragracing is offline   Reply With Quote
Old 05-04-2012, 03:13 PM   #3
Bobby Bennett
Bobby Bennett's Avatar
Liked 14 Times in 2 Posts
So, you feel completely safe running against an 8-second car with a stock 1960's style unit or something like that?
Bobby Bennett is offline   Reply With Quote
Old 05-04-2012, 03:28 PM   #4
Barnstorm
Barnstorm's Avatar
How about a SS/AH [ or most SS Mopars] having a catastrophic crank failure at 9500 with the centerlink thru the pan? This was a big topic at Indy several years ago wishing for rack and pinion. Catasrophy waiting to happen. NHRA said "yeah...we gotta take care of that".
Old 05-04-2012, 03:31 PM   #5
NBD MGT
If the parts are new or in good shape I would.
Do you think a rack (especially a typical aftermarket drag racing version) is actually as strong as the old stuff (designed back in a day when there were many many many dirt roads with pot holes)?
Think about the mounting pads on the rack.......
NBD MGT is offline   Reply With Quote
Old 05-04-2012, 03:52 PM   #6
jaythorne
Liked 6 Times in 5 Posts
i say leave a little stock in superstock
jaythorne is offline   Reply With Quote
Old 05-04-2012, 04:07 PM   #7
NWDragracing
Do you also mean that FWD should stay FWD and not converted to a RWD???
Old 05-04-2012, 08:14 PM   #8
Ernie Neal
Ernie Neal's Avatar
Liked 328 Times in 80 Posts
I didn't see that anywhere! I have built several of these fwd to rwd cars. And if youv'e never tried it, it's quite a project. Starting with aftermarket, struts and brakes, making a firewall, driveshaft tunnel and transmission tunnel and yes mounting to rack. I will say, I could build a rwd car 4 times quicker than fwd conversion and may do one soon to take advantage of an easier index. As far a rack for steering verses steering box, I see a weight advantage and for those drag links through the oil pan (chevy II) It would be easier to build a good pan. I think the rule is fine the way it is. sorry Bobby
Ernie Neal
SS 354
Old 05-04-2012, 04:12 PM   #9
NWDragracing
Again, it all depends what they have for a front suspension and frame.
Most of the SS/AH cars have a Lamb Components suspension system that makes them safe.
However, like it was implied earlier. what happens if the centerlink is damaged due to an engine putting a few windows in the block?
I have also many GM cars develop cracks in the lower arms, elongate the bushing and ball joint holes and eventually fail.
Old 05-04-2012, 05:47 PM   #10
Todd Boyer
Jeez, I was disappointed when they got rid of stock rear springs...
