Old 03-13-2012, 11:20 AM   #13
Frank Bialas
Frank Bialas's Avatar
Liked 23 Times in 13 Posts
Default Re: Why all the LT-1 B, C, and D stocker for sale?
Originally Posted by Jared Jordan View Post
Frank,
I don't think anyone has YOU covered in weight. I mean the car, of course.
Jared, your right! I can't just add some junk to my trunk. To run C/SA I have to add over 200 lbs. and it needs to be distributed through out the car if you like your rear bumper!!! Larger radiator A/C-high altitude type +13lbs on front,different transmission&ratio---converter/real tight,very deep pan +27lbs.change out the whole rear end housing and ratio + about 12lbs. A 100lbs. gets bolted in and the rest in the box, a little insurance weight and WAA-LAA your almost 4000lbs.
Frank Bialas 1570 STK
Frank Bialas is offline   Reply With Quote
