Old 01-31-2012, 11:44 AM   #5
Mike Graham
Liked 341 Times in 67 Posts
Default Re: mh air ride problem
Originally Posted by Chuck Westcott View Post
Mike,
What does your Air gauge read, there are both relays and air solenoids. If you don't see anything obvious call Freightliner Tech. Sometimes putting in D will trigger the emergency release for the Bags. What ever you do - Don't Drive it.
Chuck
I have no air to the rear air bags. the front is ok. Tank pressure is 125lbs and the dump
valves work ok. The rear height controller works if I supply external air.
It's hard to tell where the air lines go. Do you know where the solenoids and/or check valves would be located? Unfortunately driving it is how I discovered the problem.
Mike Graham
Mike Graham is offline   Reply With Quote
