Old 11-22-2011, 01:48 PM   #1
cutta
cutta's Avatar
Liked 5 Times in 2 Posts
Default Re: 2012 Rules Are Posted
Originally Posted by Ed Fernandez View Post
Not backhalved they shouldn't be.
I was referring to current stock legal darts/barracudas to be allowed to convert over to a hemi and run in one of the new classes since the weight breaks are for super stock only.
Adriel Paradise, Paradise Racing Team
Driver/Crew Chief(at least my dad claims me to be)
B.S. Mechanical Engineering, University of Arkansas
cutta is offline   Reply With Quote
Old 11-23-2011, 02:40 PM   #2
Liked 1,833 Times in 416 Posts
SECTION 10A: STOCK CARS, ENGINE: 1, ROCKER ARMS (Page 5)
OEM or OEM-type aAftermarket rocker arm permitted. Either adjustable pushrods or adjustable OEM rocker arms permitted on any application, but not both. Aftermarket rocker arm must be identical to OEM. Either adjustable pushrods or adjustable OEM rocker arms permitted on any application, but not both. OEM roller rockers permitted ONLY if application was originally equipped with roller rockers.
Note that the part in red is actually "struck through" in the NHRA publication, meaning it is the old rule that was amended and no longer applies. The part in blue is the new rule and the portion of the old rule that remains.
So here is what the new rule, by itself, actually says : Aftermarket rocker arm permitted. Either adjustable pushrods or adjustable OEM rocker arms permitted on any application, but not both.
The removed the part of the rule requiring the rocker arms to be identical to the OEM rocker arms.
What that means is that aftermarket rocker arms no longer need be identical to the OEM rocker. The only aftermarket rockers that are not identical to OEM rockers are race type roller rockers.
Note also that the rule as written and published is exceptionally and unacceptably vague. Nowhere does the new rule stipulate or specify that the OEM ratio or mounting configuration must be retained. By the letter of the rule, shaft mounted 1.9:1 rockers are not prohibited.
Now, of course, the NHRA position on this will revert to their standard "just because we did not tell you that you could not do that, does not mean that you are allowed to do that."
