#1 | |
Liked 393 Times in 153 Posts
That is true of pre 1972 cars Ralph, but after that they were "net" with everything installed as today. I used mostly mid 70's cars for that reason. Regardless of how, or who done what, potential is what a class racers is after. If eng A is rated at 99% of it's potential, who going to try it? Nobody. If eng B is rated at 50% of it's potential, everybody will consider it....unless it's hidden, then only Billy Nees or Bob Shaw will find/try it! LOL! So the only real question is then, what is the true potential of the new motors? Then, can they be factored the way the old motors were? In other words; A is 400hp@ 80% = 500hp 100% B is 400hp@40% = 1000hp 100% If both engines start out at .58 factor, one will obviously cause a ruckus.(as we have seen with turbo or supercharged engines) So, do you rate older or N/A engines at .58 to start and pressurised eng 1.1 to start? What is a fair place to start pressure engines? Maybe starting them at 1.3hp/cu.in IS fair? |
Banned
This was still going on in the early 1980 as I was involved with a program that they called Stock Engines, Ford would buy cars from GM, Chrysler and other manufactures run Performance, Fuel Econmy, NVH and Emission Tests then pull engines out of vehicles run them on Dynod then send to Engine Build-Up dissamble and measure them. Then puld a report on each vehicle.
That is true of pre 1972 cars Ralph, but after that they were "net" with everything installed as today. I used mostly mid 70's cars for that reason. Regardless of how, or who done what, potential is what a class racers is after. If eng A is rated at 99% of it's potential, who going to try it? Nobody. If eng B is rated at 50% of it's potential, everybody will consider it....unless it's hidden, then only Billy Nees or Bob Shaw will find/try it! LOL! So the only real question is then, what is the true potential of the new motors? Then, can they be factored the way the old motors were? In other words; A is 400hp@ 80% = 500hp 100% B is 400hp@40% = 1000hp 100% If both engines start out at .58 factor, one will obviously cause a ruckus.(as we have seen with turbo or supercharged engines) So, do you rate older or N/A engines at .58 to start and pressurised eng 1.1 to start? What is a fair place to start pressure engines? Maybe starting them at 1.3hp/cu.in IS fair?[/QUOTE] |
Liked 279 Times in 68 Posts
The new Boss 302 is about the same as the Cobra Jet 302 except the Cobra Jet has more compression. The Boss is rated at 444 hp from the factory and the Cobra Jet is 325. I just watched a test on Motorweek of the Boss 302 and it went !2.4 seconds in the quarter at 124 with street tires and full exhaust. Evan you can forget the weak BS all these cars are bogus and way under rated.
Greg Hill 4171 STK |
#4 | |
Liked 19 Times in 7 Posts
ss/gt 93 t-bird |
It's probably because the motor in the mustang has zero drag racing development done to it and ours has over 20 years worth. I guess the reason there is only one other car in the country with our combo is that it's so under rated. We'll be hard pressed to out run it once it's got the right converter and cam and all the other things you have to have to run fast.
Greg Hill 4171 STK Last edited by Greg Hill; 09-27-2011 at 04:59 PM. |
Liked 174 Times in 39 Posts
Probably because I was .08 faster in the first 60 feet, and also it has had virtually nothing done to the motor. Oh yeah, and he was going over 1.5 mph faster than me at the 1/8th even with very little work done to it. Go ahead and build a car like mine if you think it's so soft.
3207 D/SA, C/ED |
#7 | |
Liked 282 Times in 103 Posts
Don't want to get into any discussions of who works harder,because your cars obviously run very well,but I am just curious Greg and Andrew.....did I read the weight sticker right on Andrew's car? It is rated from the factory at 360 and NHRA rates it at 325? How did you get NHRA to take 35 horsepower off of the factory rating or was it always like that? |
It has been 325 for quite some time.
Tony Janes 7941 STK, SS |
#9 | |
ss/gt 93 t-bird Last edited by dwydendorf; 09-27-2011 at 07:49 PM. |
#10 | |
And yes, my car has been rated at 325 for a long time
3207 D/SA, C/ED |
