Old 06-24-2011, 01:53 AM   #1
Pvt Parts
Pvt Parts's Avatar
Default Re: Sunoco supreme
Originally Posted by The Hawk View Post
I absolutely agree with that. I`ve had 10 gallons in my stock gas tank all winter and have it pass the first race out. Also curious what some of you are paying for it.
Not surprising. "Stale" gas usually passes. If you're "close", the problem is getting fresh gas to pass in 80 to 90 degree heat.
Old 06-16-2011, 09:58 AM   #2
Mike Croley
Originally Posted by astikhossw View Post
race fuel, i have been using this fuel for some time but need to know if there are any other fuels that can help pick up the ET a little more.I am pretty close to the index at 10.55 but have not tried any other fuels to see if they help (mostly because of the expense)but if there are any that has used Sunoco supreme and pick up ET using other fuels i will sure try it.
It's possible to pick up ET slightly by changing fuels , even brands of fuel . The pick up could come from increased torque , increased power , better throttle response , or a little of all of the above . Usually , any pick up you see will be due to the new fuel being a little more compatible with your engine specs and set-up .
And yes , some brands of race fuel are a lot more expensive than others. But spending a lot more isn't really necessary . Compare race fuels that offer the motor octane you need .
Mike Croley is offline   Reply With Quote
Old 06-16-2011, 02:19 PM   #3
njk53
Mike you are absolutely right. If you have a car that is a 9:1 or 9.5:1 it is going to be less sensetive to fuel compared to a motor that is 12.5:1.
Our motor is 9:1 and I'll be willing to bet we could get it to run pretty good on a fuel with a lot less octane rating than 110.
Nelson Kowal
Stock 345
Old 06-22-2011, 08:22 PM   #4
jlstoec
In my 12.8:1 540 I have not seen a difference between Torco, Rockett, or VP. I did give Q16 a go but don' think I got the tune right and didn't see gains.
jlstoec is offline   Reply With Quote
