Old 04-25-2011, 05:50 AM   #12
Charley Downing
Liked 633 Times in 88 Posts
Default Re: Cobra Jet Comment
If these so called bogus HP happened in 1968 why is there so much crying about it happing with the new cars today? It’s just S/SS history repeating itself.
To Danny and others. S/SS is like chess, it’s all about making the right moves at the right time. If you spent your hard earned money on a car that could run 1.40 under YOU should decide when to make it go fast and when to make it go slow. Not someone behind a computer. And just for the record they already have WFO day for S/SS. You can go to No Problem Raceway and run the sports national CIC race.
Just on a side note for all you clowns. Give the CJ/DP thing up. They are here to stay bogus hp’s and all.
NEW FORUM RULE effective 4/25/11. You can only make a post about CJ or DP (good or bad) if you race/own a NHRA or IHRA S/SS car. Your car MUST also run a minimum of .50 under the NHRA index or .80 under the IHRA index. If you do not meet these requirements the MAD Hawaiian will delete your posts ASAP. (Terry this means you can’t post anymore about CJ or DP’s)
Charley Downing 3548 STK
Charley Downing is offline   Reply With Quote
