Liked 759 Times in 379 Posts
If you have questions as to whether your current converter is optimum for your combo speak to Charlie Plott at ATI.
Be prepared to provide him with factual data, including but not limited to what does the converter flash to on launch, what RPM does it fall back to on the gear change(s) and what RPM is it crossing the stripe at and the only way you'll know this is with a playback tach or data logger. As to my car's specs... 522 BBC, turbo400, 4.57 gear. ![]() Slowed to run low 9.0's all season long at near 150 ![]() More importantly what are the specs of your car/combo? Last edited by 1320racer; 02-21-2011 at 10:50 AM. |
#2 | |
#3 | |
If you think a turbo 400 "gets you going with the bigger 1st gear" why aren't you running one?
what is the best and average ET, MPH and 60 foot and at what weight? Also how many passes on this combo as it now? Need all the details of the car/combo to determine if it's running near optimum and if the converter is right. The devil is in the details and if the combo is mismatched, you'll never get the 60 foots you're looking for regardless of whose converter is behind that engine. Did you read this... Quote:
#4 | |
how big are the heads, what is the cam @ .050, what intake manifold and what carb?
195 comp. ported AFR heads solid roller 2.58 / 2.65@ 50 Victor Jr. 2" spacer with a hp 950 Just under 11.1 compression. 1 3/4 headers
You don't have enough gear, nor do you have enough low gear in the transmission. You don't need to try to "fudge" anything by telling them you're putting it behind a Super Stock engine, besides, when you give them the specs, they'll know. You need a 4.88 or a 5.13, and about a 1.90 low gear.
Alan Roehrich 212A G/S |
#8 | |
That said, the quick fix is more gear or a 3 speed trans and a shorter tire. Here's an example of a 3160 lb. footbrake launched ride slowed every week to run low 10.0s with a sbc under the hood backed by a 1.80 1st gear glide that leaves with a best 60 foot to date of 1.27 and has run 9.77 @ 138+ with a manifold having less plenum volume than yours and no 2" spacer ![]() Last edited by 1320racer; 02-21-2011 at 02:53 PM. |
#9 | |
Charlie Plott was the only one who could get my converter right a while ago, They kept it @ 4200-4400 Charlie looked at it and mentioned some ss cars, took the converter @ no charge and brought it back and said its loose enough and has the proper stator now When in doubt ask for Charlie and if he is busy leave a message One of the nicest guys out there. Art is the one who specd it @ 4200-4400 |
