Old 01-03-2011, 11:24 AM   #1
Jeff Lee
Jeff Lee's Avatar
Default Re: Can I remove my dash vent?
Originally Posted by fredjohnston View Post
not correct on the part about not being able to run a racepak or other dash in a stocker.
So they no longer have "full stock dashboard including instruments, fresh air ducts and controls must be retained" in the NHRA rulebook?
See Stock / Electrical / Instruments.
Jeff Lee 7494 D/S '70 AMX
Old 01-03-2011, 11:32 AM   #2
Ed Wright
Ed Wright's Avatar
Yep, I had to put the AC/Heater controls back in my dash for SS. Guys with the Firebirds do put gauges in their AC vents. I'm probably the only one not to. I see cars with the Racepack dash on the collumn in front of the factory cluster, don't think you can pull the cluster.
Ed Wright 4156 SS/JA
Old 01-03-2011, 12:10 PM   #3
Larry Curtis
Larry Curtis's Avatar
Liked 9 Times in 2 Posts
I am retianing my factory cluster. It is a lot more difficult to put the race pak in front of the stock cluster than in front of the heater register. Also I have been told (not from NHRA) that I could remove the heater controls because the car is a heater delete from the "factory". Maybe I should call NHRA tech for clarification?
Thanks,
Larry
Larry Curtis is offline   Reply With Quote
Old 01-03-2011, 01:39 PM   #4
Rory McNeil
Liked 1,104 Times in 302 Posts
If a car is indeed a factory "heater delete" car, then why does it have any heater controls in it?
NHRA 6390 STK
M/S 85 Mustang
Old 01-03-2011, 01:54 PM   #5
Larry Curtis
Your guess is as good as mine.
