Old 11-15-2010, 06:50 PM   #14
keith ohanesian
Default Re: A gift from Ford for the lower classes @235hp
It has a 65 mm throttle body!CNC'd 3 valve head! That thing should start at 260!
I don't care let those thing run with us.. I grew up watching Dale Sr. race and learned how to put someone into the wall.
Originally Posted by JRyan View Post
Charlie.
The 140hp 307 Olds is rated 240 hp. The 85 flat top 305 in a Camaro is rated 262, an 82 dish piston Camaro is 244 and the Malibu 230. Wades 283 is rated 217hp and the 138hp roller Olds is 213hp.
Both of the engines rated less then the 281 have far less compression and the 283 has a .399 lift cam. The roller 307 has a horrible intake and head design.
So @ 235 it may not be greatly underfactored but it should be a lot better then the dished piston 305 or 140hp Olds for certain.
Rick Ryan
No prep is king
keith ohanesian is offline   Reply With Quote
