Old 09-16-2010, 09:56 AM   #11
art leong
Default Re: Titanium Valves Allowed in S/S?
Originally Posted by Jess Suter View Post
I cant stand it anymore
The simple solution is to implement the valve spring rule-period! Stock spring pressure. There would be no 9800 rpm hemis or 9800 rpm anything else. IMO this was the downfall of stock. Lower rpm no acid heads or manifolds needed. No $1000 lifters no $7500 heads. Wouldnt matter cause they cant flow at lower rpm. Just my 2 cents
They are talking about Superstock which has never had to use stock valve springs.
If you went back to the stock spring pressure in stock an awful lot of cars would slow down a bunch. And a lot of camshafts would become short pool cues.
Art Leong 2095 SS
