#1 | |
Liked 101 Times in 52 Posts
Do the shipping weights for these new cars include the discarded A/C units and cruise control, etc.? (I bet the 69-71 ish weights are for a stripped down car.) What NHRA did not do was reflect the weight reduction of items such as aluminum brakes and things. The easiest way to eliminate the seat weight advantage is going back to every car must be nose heavy. (Anyone recall when that was lifted from the rule book?) It would eliminate all the trick stuff advantage. Does a guy with a 1970 six cylinder Maverick really need $3,000 of aluminum brake pieces to stop? No, but he does to run with the others in his class if they loose the weight there. I could never understand how NHRA and IHRA let guys race without fire jackets or pants. If your V/SA car is hit by an A/S car and pinned to the wall, don't the flames burn you too while you cannot get out? Look at some of the early Top Stock images. The A/B/C Stock Eliminator guys had jackets while the Top Stock guys had short sleeve shirts. For those of you not wearing fire resistant pants, I'm going to help at the hospital again this weekend, come along with me and see if those bozo nylon pants help you at all. We won't even get into back/neck injuries... |
Hey Dan would that little guy be SB?? LOL.
Liked 54 Times in 27 Posts
Several years ago I welded tabs on the two sliding sections of each track and ran a bolt through the tabs to lock the seat. If the seat has to move, remove the bolt on each track.
Liked 2 Times in 1 Post
If you could get a couple of seat manufacturers to $hake hand$ with the NHRA ............
Liked 262 Times in 74 Posts
I've been saying it for years, But it's a sad State of affairs when someone has to get killed to change the safety rules. I know of very few racers that will complain when they update the rules to make his car safer.
Steve Polhill 3520 STOCK, COMP |
