Old 06-14-2010, 06:25 PM   #1
bubski
Liked 165 Times in 60 Posts
Default Re: Drooze & Teuton
Originally Posted by Owen S Quirion View Post
I must be missing something here. If I ordered a cam and thought that I had 1.6 rockers, why would the manufacturer grind my cam short so that it would check ok with 1.65's? I would have thought that the lift should have checked too high if 1.65's were used on a cam ground for 1.6's. Go ahead and educate me.
its called second time around no refactoring. i guess when you go fast you just come up light, drain fluids, get tossed by simple little [human error hahaha] . it happens to all of us. just happens a little too often to some of them
bubski is offline   Reply With Quote
Old 06-15-2010, 01:14 AM   #2
Phillip marvetz
Phillip marvetz's Avatar
The first cam I ordered for my stocker came up short, .390 when it was supposed to be .410. Rockers would have fixed it cheaper than buying another cam if they had been available. Any body want a slant six stocker cam? The cam grinder wouldn't take it back. I for one am supprised NHRA cares about the ratio as long as the the lift checks good. I guess I'll be checking that when I build engines from now on...........
2009 V/SA Record Holder
