I would def. go with the Metric with 5.38s and the 92.5 ro 30x9 radials. You can run those tires over 40psi. Will put you around 6500-6600 from 100-102 through the traps. Keep it cheap as possible and see where it lands. Maybe better than you thought. I was curious on the carb though. Can it be a dual jet or is it the computer carb.
George Roussel Jr. 4262 1996 S10 n-o-p/sa |
#2 | |
Liked 7,780 Times in 1,743 Posts
#3 | |
You guys DO know ,you're going to have to put a custom 12 bolt in that car, in order to be able to play with the gears? I'd figure out a baseline on the ratio, and then ,when you go lower and don't pick up 60' but lose MPH, go back to where you were! BTW, if you're not too deep into that car, I'd back right out of it ,and into a 78 Camaro 305 2 GC 2bbl car . You could use the 8.5 rear that comes in them.
Liked 169 Times in 53 Posts
Thanks to everyone for replies on U/sa. Will probably ask for more help as we get further along with this thing.
#5 | |
The only other thing to consider (other than having a car vs. finding and buying a car) would be the difference in weight between the two. The Monte Carlo has to weigh only 3170 to make U/SA while the Camaro has to weigh 3770. I like towing light cars.
#6 | |
I actually didn't realize the hp rating on the 267 was that low. It might be worth a shot for someone willing to spend the money on the rear end. Maybe some math major could analyze the specs and give us a hp and torque potential.?
Liked 54 Times in 18 Posts
Keep it coming guys, I love the modern low class tech lessons. Must be from my old P/S junior stock days & old age.
It wouldn't be too expensive if he could find a GN rear!
Liked 66 Times in 37 Posts
I would not put 1 cent into that combo but I have a brand new set of .060 cast pistons in the box for FREE. It's the carb! The 305 2G is a possible and by the way I have one for sale HAHA just needs the motor. I have not had much luck with any two barrel.
We're putting a Moser 12 bolt in the car. I realize it's overkill for a U car but I have a few ring and pinions of various ratio's as spares so we can see which one will work the best when we get it running. we're starting out with a 5.13 and go from there.
