Liked 7,745 Times in 1,740 Posts
It's about time somebody did one of them! I've had one of those sitting on an engine stand for years. I don't think that it's a great combo but I think that it can be decent. Don't over cam it and don't over gear it. It doesn't make a lot of compression so keep the cam duration on the small side to start out. It also doesn't have a lot of carb to work with so your peak RPM will probably be in the range of 6200 to 6400 RPM. It probably is going to want a really small header too. Probably even as small as 1-3/8 primary and less than a 2-1/2" collector. Might even try a 8 into 1 header if there's room underneath. At least 2.75 low gear trans.
When you're working on really restricted engines just remember one thing. It can't make horsepower because you can't spin it so try to make torque. Whatever you think that you need, that is probably too big. Not like an average race car.
Although I've probably been doing this as long as Billy Nees, it's obvious to me that he knows more about it than I do. I feel that I just learned something. Or maybe it just reinforced things that I thought I knew.
Bobby & Norene Zlatkin L/SA |
I was pitted right across from Billy at G-ville and only talked to him a couple of times during the whole weekend. I wish I could have sat down with you Billy and chewed the fat for a while! Billy has forgotten more than the average guy knows! next time Billy, next time. Jim
P.S. I hope Don is feeling better! Get well soon Don! We love you! Jim
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
I would def. go with the Metric with 5.38s and the 92.5 ro 30x9 radials. You can run those tires over 40psi. Will put you around 6500-6600 from 100-102 through the traps. Keep it cheap as possible and see where it lands. Maybe better than you thought. I was curious on the carb though. Can it be a dual jet or is it the computer carb.
George Roussel Jr. 4262 1996 S10 n-o-p/sa |
#5 | |
#6 | |
Liked 5,124 Times in 1,953 Posts
You guys DO know ,you're going to have to put a custom 12 bolt in that car, in order to be able to play with the gears? I'd figure out a baseline on the ratio, and then ,when you go lower and don't pick up 60' but lose MPH, go back to where you were! BTW, if you're not too deep into that car, I'd back right out of it ,and into a 78 Camaro 305 2 GC 2bbl car . You could use the 8.5 rear that comes in them.
Liked 169 Times in 53 Posts
Thanks to everyone for replies on U/sa. Will probably ask for more help as we get further along with this thing.
#8 | |
The only other thing to consider (other than having a car vs. finding and buying a car) would be the difference in weight between the two. The Monte Carlo has to weigh only 3170 to make U/SA while the Camaro has to weigh 3770. I like towing light cars.
#9 | |
I actually didn't realize the hp rating on the 267 was that low. It might be worth a shot for someone willing to spend the money on the rear end. Maybe some math major could analyze the specs and give us a hp and torque potential.?
#10 | |
Liked 100 Times in 45 Posts
It is an adventure riding with him on a long run.So far I've survived two road trips.Half the fun is him trying to keep the Geo at 50 MPG on the trip.
Former NHRA #1945 Former IHRA #1945 T/SA |
