Old 11-21-2009, 01:53 PM   #1
BobUnkefer
BobUnkefer's Avatar
Default Stocker engine Input please
68 Camaro that is currently a crate motor car, engine needs freshened, rest of the car works good, is fresh and race ready, .
Question is,,,,, for NHRA Stock eliminator which way would you go power wise?
396/375
396/325
350
327
and WHY? I have my thoughts, but curious as to the more experienced that inhabit this forum as to which way you would go.
It is also my understanding that in a 1968 Camaro, it's a 'Glide only behind a small block, but a 3 speed auto is ok with either big block, Correct?
Thanks for your thoughts,
Unk
BobUnkefer is offline   Reply With Quote
Old 11-21-2009, 02:05 PM   #2
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Default Re: Stocker engine Input please
396-375 says Stick only for 68
Bob Pagano A/SA
Old 11-21-2009, 02:16 PM   #3
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
I would go either 327 or 350. This way you can run in both IHRA and NHRA. A PG is the only automatic behind these combinations. The 327 is a great stick combination!!!!!!!!!!!
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 11-21-2009, 02:38 PM   #4
BobUnkefer
BobUnkefer's Avatar
Bob,
IHRA has 396/325 in their book I'm sure. We're looking to make car a legal NHRA stocker and get away from the crate motor aspect.
Looking @ Nitro Joe's stats, It doesn't appear that a '68 Camro/350 is a combination found very often, yet there are numerous 327's. Looks like they've defactored thr 350 combo as well. Is the 350 just not a workable combo, or is the 327 that much BETTER?
BP, missed the stick only on the 375hp
so that leaves a 396/325 for D/SA, or the 350 or 327 for G/SA if I'm reading correctly,,,,,, and please correct me if I'm wrong.
Old 11-21-2009, 04:31 PM   #5
Jeff Lee
Jeff Lee's Avatar
Old rule was "PG Only", now you can run a 3-speed auto in lieu of 2-speed auto. They seem to go quite a bit faster with this change...
Jeff Lee 7494 D/S '70 AMX
Old 11-21-2009, 04:53 PM   #6
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Cool Re: Stocker engine Input please
Not in stock.....Super Stock only.
Old 11-21-2009, 05:11 PM   #7
Tom Meyer
Liked 354 Times in 120 Posts
I have yet to switch to the three speed in my 283 SS nova, just how much faster are they?? I may have to after Als hits on my combo with more to come I am sure. So the question is is it worth the money to make the switch?? Thanks Tom
Tom Meyer 5240 SS Stock ???
Old 11-21-2009, 05:39 PM   #8
Liked 1,928 Times in 434 Posts
The 396/350 for 68 carries only 15 more HP than the 396/325, and gets 0.060" and 0.080" more cam lift. You could run the 396 and pick the HP rating by just changing cams. And you get to run a 3 speed automatic with the 396 engines.
The 327/275 and the 350/295 look to be decent, if you have to run an automatic, and it has to be a PowerGlide, I'd think the stroke of the 350 would help the PowerGlide at least enough to make the 15HP difference up.
Old 11-21-2009, 05:45 PM   #9
Jeff Teuton
Liked 325 Times in 50 Posts
Wink Re: Stocker engine Input please
You need a Mopar.
Jeff Teuton 4022 STK
Old 11-21-2009, 05:49 PM   #10
BobUnkefer
BobUnkefer's Avatar
Originally Posted by Jeff Teuton View Post
You need a Mopar.
Got one of your new Challengers ready to go yet?
