Old 05-24-2009, 02:19 PM   #1
john bertges
Default Re: Another Ford in GT/AA
jeff's 351 is not a 330hp it is a low comp/hp combo that came with a auto
john bertges is offline   Reply With Quote
Old 05-24-2009, 04:43 PM   #2
Terrance Smith
Guest
Posts: n/a
I wouldn't call 285 factory hp and 324 NHRA horsepower a low rating. The engine Jeff is running is an Closed Chamber combo that came in 71 Torino GT's, Mach 1's, Mustangs, Torino Cobra's etc...... compression ratio is 10.7 for the 285/324 versus 11.0 for the 330/330hp Boss.
Old 05-24-2009, 08:04 PM   #3
Lynn A McCarty
Lynn A McCarty's Avatar
For a cylinder head that has the volume of a Cleveland, with a large valve size, and 11.0 to one compression, 324HP makes it a pretty favorable combo. I dont know many heads that will flow what a Cleveland head will. They are about the best out there.
Lynn A McCarty 3470 SS
Lynn A McCarty is offline   Reply With Quote
Old 05-24-2009, 08:10 PM   #4
Terrance Smith
Guest
Posts: n/a
I wish I had a set of those good CC Cleveland heads and intake for my old ride.
Old 05-25-2009, 08:34 AM   #5
BlueOval Ralph
Banned
Actually the Cleveland heads are not that big, a lot of cc but they are only 2.80 Inches of cross sectional are at the short turn.
BlueOval Ralph is offline   Reply With Quote
Old 05-25-2009, 12:08 PM   #6
Lynn A McCarty
2.8??? That is good for about 470 inches to 6500 RPM with zero limitations on HP. Gesso Pete, we are more like 2.2 with a 14 degree valve angle and a hundred more cubic inches to do the same thing. Want to know the equation for CSA required to prevent limiting HP?
CSA required* = bore * bore * stroke * RPM/0.00353*(614fps)
*minimum cross sectional area throughout the length of the intake port. For those too lazy to do the math, there are calculators where you can just plug in the numbers required. (If you want to calculate fps numbers that is fine, just remember that it is required that you double measured fps to obtain actual.)
http://wallaceracing.com/ca-calc.php
http://wallaceracing.com/chokepoint-rpm.php
Old 05-25-2009, 12:32 PM   #7
Terrance Smith
Guest
Posts: n/a
Great info Lynn!!!
