Old 04-10-2009, 10:11 PM   #31
Chad Rhodes
Default Re: Blown, injected, 4-valve CJ's at Ennis...
Originally Posted by bsa633 View Post
But you think it should work the other way too right...no freebies when the air is an actual -1000-1500 or whatever it could turn out too...or?
i'm saying you play the hand you are dealt, and race in the air you are in. if you were in montgomery in 02 i beleive, you got -1700 feet, and ton of records were set. either you factor ALL back to seal level for the actual DA at the time run (regardless of whether the track's altitude is 5000ft or 5ft), or you factor NOTHING
Chad Rhodes 2113 I/SA
