no, a bogus track is one where they subtract .4 from your ET and give you the record for it, even if the actual DA is sea level at the time
Chad Rhodes 2113 I/SA |
As a point of reference Erich Bollman ( AA/SA '08 Mustang CJ ) qualfied # 16 at Atco -(remember, this is 1/8 mile) - 6.162 -.868 under . Also he went Top Speed of the event @111.86 MPH .I have no idea what his weight was on those runs .Carry on ..............
Jack Matyas 1547 FS/C 2015 Camaro COPO # 62- 2012 Camaro Convertible COPO |
#4 | |
Could you name some tracks and Division Directors that allow Tech to do that ?? |
ok the .4 was an exxageration. but you can set a record at an altitude factored track without putting the number on the board. and they are exempt from getting hit with HP. It is BS
This post is Bogus!!! Once again these cars have not done anything wrong but show potential. Robert Pond and Bobby DeArmond have been running nines for the last couple years and they haven't generated this kind of attention. Geez, this is ridicoulous!
Liked 6 Times in 4 Posts
Have either of them (DeArmond or Pond) ever run anything approaching 140 mph?
MPH is the telling number in drag racing. It is a lot more reliable as a horsepower-to-weight indicator than e.t. slips because bite will vary from track to track, and when the hook changes, so does the e.t., but the mph is a lot more constant, regardless of e.t. variations. These cars have had very little development (track) time and are already running numbers that no one else can approach, with years of development. THAT is the problem; all provided by the 425hp factor that NHRA has bestowed upon them (and the 700+ horsepower they seem to be able to produce, at will.) Given these circumstances. don't you think this situation is worthy of some discussion? I do...
Bill Last edited by bill dedman; 04-08-2009 at 02:25 PM. |
Liked 16 Times in 11 Posts
Hay Bill, What I really want to know is what was NHRA smoking the day they put that factor on the CJ's........I WANT SOME !
Bob Pagano A/SA |
Liked 444 Times in 145 Posts
Jack,
CJ at Atco to the 1/8 = 6.16 et @ 111.86 mph. CJ at Dallas to the 1/8 = 6.210 et @ 110.01 mph and 1/4 = 9.794 @ 140.17 mph. Looks like the CJ at Atco could have gone close to 142 mph. Smitty, It may look like Ford and Mopar have pulled this stunt off but heads have begun to roll over this mess. Things can still change. How will it hurt you, if these cars are moved to another class?
Bruce Noland 1788 STK |
Bob Pagano asked: "... what was NHRA smoking the day they put that factor on the CJ's........I WANT SOME !"
The same thing they were smoking when they decreed that somebody driving a Stock Eliminator car needs to wear S.F.I. pants.... and that seat belts need replacing ever TWO years, when even NASCAR allows them to be used for FIVE....
Bill |
