#31 |
I have it on good authority that the language of the rule is going to be changed to delete the word “primary,” thereby making what the Williams Bros had done legal. Doesn’t help them this weekend though.
It’s like getting ticketed for going 35 in a 25 mph zone and then they raise the speed limit the next day.
Jared Jordan 9 B/SA 2024 Jeg's D7 All Star - Stock |
#32 |
Liked 2,765 Times in 978 Posts
How many of these cars made R1 as alternates?
------------ Not Qualified ------------ 129 333 AA/S Brett McFarland, Manchester OH, '68 Camaro 9.875 10.70 -0.825 130 5351 G/SA Keith Hildahl, Northfield MN, '73 Mustang 11.178 12.00 -0.822 131 3657 O/SA Marty Buth, Freeport IL, '84 Mustang 12.331 13.15 -0.819 132 338H FS/AA Tony Fagnilli, Caropolis PA, '19 Camaro 8.584 9.40 -0.816 133 1925 K/SA Tim Barrett, Fort Ann NY, '69 Camaro 11.840 12.65 -0.810 134 329 U/SA Dan Tool, Jacksonville IL, '79 Mustang 14.049 14.85 -0.801 135 5077 B/S Jerry Mooney, Wall SD, '68 Mustang 10.459 11.20 -0.741 136 3027 I/SA Doug Deck, O'Fallon IL, '99 Mustang 11.560 12.30 -0.740 137 2586 V/SA McNeal Freeman, Conyers GA, '87 Caprice 14.768 15.50 -0.732 138 3355 R/S Timothy Weinzapfel, Mount Vernon IN, '66 13.220 13.95 -0.730 139 7832 EF/S Gary Lucier, Kingman AZ, '84 Daytona 16.760 17.45 -0.690 140 1329 D/S Denny Ford, Eighty Four PA, '62 Biscayne 10.817 11.50 -0.683 141 3139 EF/S Ron Seibenick, Perry OH, '86 Tempo 16.812 17.45 -0.638 142 319 F/SA Jim Stone, Henderson KY, '80 Corvette 11.214 11.85 -0.636 143 5502 A/S Paul Anderson, Lewiston MN, '69 Camaro 10.798 10.95 -0.152 |
#33 | |
Liked 498 Times in 244 Posts
Were the idle screws removed as required? If so they probably should have been given the option of fix the holes... A 15 minute fix with a little solder... Was that after all qualifying was over? Were they DQ'd from class? Or the hole event? Kind of a dumb rule in my opinion... Don't even see the secondary idle screws as a performance advantage... Especially when the rules state "any internal modification allowed"... Or did I misread that? Can someone explain the advantage, I'm always willing to learn something new... |
#34 | |
Liked 591 Times in 102 Posts
Julie Jordan 7549 STK |
#35 | |
Liked 1,031 Times in 283 Posts
Qualifying and class were over. There was no chance to fix it and run again. There are alot of things that are not a performance advantage that are illegal in class racing. Its not techs job to decide what they will let go thru in the barn because the rule doesnt help performance. Someone was told.they couldnt run without fog lights in their bumper cover. Luckily they had them and it was taken care of.before Qualifying and class was all done. I heard a tech official say " we bounced ....... for the same modification 2 years ago, we cant let it go today"
Duane Hoven 1342 SS/GT Last edited by 1347; 08-30-2025 at 05:27 PM. |
#36 |
Liked 1,968 Times in 595 Posts
I just took a few minutes and read the carburetor section of the rule book for Stock Eliminator. The rule clearly states that you can drill the primary throttle plates. It does not say you can drill the secondary throttle plates. It does state that no other modifications can be done. If indeed the secondary throttle plates were drilled the carb is illegal by the rule book and the interpretation of the rule is correct by the tech department. If it passed before it doesn?t supersede the rule as printed at this time. I have been tossed in the past for an insignificant detail like this. All you can do it?s take the penalty and move on. Fix the issue. Have the repair inspected by tech before the next race and run even faster.
Mike Pearson 2485 SS Last edited by Mike Pearson; 08-30-2025 at 04:16 PM. |
#37 | |
Liked 397 Times in 153 Posts
The idle mixture screw heads had to be "covered" to make them "legal".
Phil Molski PMR Performance S/C 1623 Last edited by pmrphil; 08-30-2025 at 04:35 PM. |
#38 | |
Liked 177 Times in 59 Posts
Tom Flowers E/SA 3860 |
#39 | |
Liked 226 Times in 137 Posts
So you turned a 735 cfm carb into a 780 cfm?
#40 |
Liked 8 Times in 5 Posts
Why is it there are NO throttle plate holes shown in the Quick Fuel 780 carb photos accepted for Stock or S/S on any of the Aftermarket sights?
