Liked 20 Times in 15 Posts
has anyone used contact cement to hold intake gaskets in place?
I have 2 problem areas. divider wall & top of port. thanks Rod in AZ. |
Liked 55 Times in 28 Posts
First I would check whether there is any gap one place vs. another meaning the heads or intake need to be "squared" and resurfaced. K&W Coppercoat spray stays sticky for days and would work well. It can be removed with lacquer thinner.
Liked 335 Times in 182 Posts
Best stuff is Permatex HYLOMAR M or equivalent--Patterson uses it on all their engines---FED 387
good tip thanks. Rod in AZ
