Liked 85 Times in 22 Posts
What kind of difference are you seeing in 60?, short time and et leaving off footbrake vs 2 step in a non trans brake car? Also on the 2 step are you leaving wide open throttle or just enough to activate it? Thanks Doug
Last edited by Doug Domm; 10-17-2024 at 11:04 PM. Reason: Changed question mark to foot symbol |
Liked 1,339 Times in 364 Posts
I currently leave off the footbrake but am interested to see what others say is quicker/more consistent
Dawson Pauley #2827 N/SA 1980 Malibu SW 2S 305/180 #2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide |
Liked 869 Times in 165 Posts
I'm going to do some testing on this topic myself soon. I think it depends on how your carburetor is set up. I've 2 stepped my car since I put the new engine in it last year, and I like being able to bump in at around 2000-2200, and then mash the throttle and not worry about the launch rpm. I've also chilled my engine a few times and haven't had a hesitation, where I've heard of racers having issues getting there cars to leave off the footbrake when they are ice cold. As far as EFI cars are concerned, I drove a car that was religiously foot braked by the owner, but I decided to use the 2 step that was in the car. It was a little faster on the 2 step (.03-.04) than on the footbrake.
1189 F/SA Defunzalo Racing Enterprises |
Liked 759 Times in 379 Posts
some are quicker and some are the same. That said, footbraker's stage RPM is typically limited by the ability of their brakes to hold the car, where's transbrake launches are not so if you stage at a higher launch RPM off the tranbrake you should run quicker assuming the car works.
Liked 373 Times in 131 Posts
.05 sec. for my 4 cyl. stocker
2 step vs. footbrake but then again it's a turbo car so maybe that data does not apply to a n/a setup
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
To borrow from former NBA great Dr. J. (Julius Erving), "I'M OLD-SCHOOL", so footbrake racing is the way I go.
Besides, that's one less part in my car that can go bad when it's supposed to be good!
Gary Hampton '86 Z24,173 V6 CF/S #5824 (#78 in 2021) Last edited by GarysZ24; 10-19-2024 at 05:58 PM. |
Liked 273 Times in 109 Posts
Are you guys using an adjustable brake pressure switch? Are you adjusting RT with brake pressure? Launch RPM? Or both?
#8 | |
Liked 708 Times in 285 Posts
I have an adjustable brake pressure switch. It has separate adjustments for ?arming? the 2 step and ?releasing?. This can effect reaction time a little, but mostly I use RPM adjustments for R.T.
Liked 705 Times in 204 Posts
I’m new to 2steps (previously raced transbrake cars) not knowing where to start I’m at 2800 rpm using an electrical switch on the pedal. I see cars that roll forward before lifting the front tires and that would seem to be the best rather than picking them up out of the beam. I haven’t tried footbrake since the first two runs on the car. I’m also going to try and compare the difference. I have bias tires on the car now and 60’ 1.37-1.39 but plan on switching to radials. Is the leave comparable or am I going back to the beginning?
Mike 7570 A/SA Last edited by Mike Gray; 10-23-2024 at 02:33 PM. |
