Old 04-13-2023, 06:33 PM   #11
Kirk Morgan
Liked 81 Times in 45 Posts
Default Re: Min assembly weight effect on ET
I dont know about horse power but it should help the engine accelerate quicker.
Kirk Morgan is offline   Reply With Quote
Old 04-13-2023, 07:36 PM   #12
Stan Weiss
Stan Weiss's Avatar
Liked 735 Times in 386 Posts
When I produced that graph I just used the weight stated and picked a distance from the center line and an acceleration rate.
How much does that weight change reduce the needed bob weight, or it other words how weight can be removed from the crank also?
Stan
Old 04-14-2023, 09:20 AM   #13
Signman
Liked 269 Times in 99 Posts
When we were looking at this back when piston rod assembly weights were enacted the thought was to remove as much weight as possible from reciprocating components and bring it toward the center rotating mass. This would be just one place to work.
Old 04-14-2023, 09:59 AM   #14
Stan Weiss
Stan Weiss's Avatar
With that in mind. Remember when looking at rod weights that only the small end weight is reciprocating and big end weight is rotational.
Stan
Old 04-14-2023, 11:22 AM   #15
Adger Smith
Liked 880 Times in 311 Posts
Depends
Rotating weight IE: crankshaft Counter weight and rod big end act like flywheel weight.
Reciprocating IE: upper rod, piston and pin and rings are a start & stop motion and absorb energy in the start and stop.
100 G off each upper reciprocating only lightens the crankshaft counter weights 100 G.
100 G. off the big end of each rod lightens each rod journal 200 G. (2 rods per journal) The end crankshaft counter weight is lightened a corresponding amount. The total effective loss of rotating is 400 G.
Adger Smith (Former SS)
Old 04-14-2023, 07:21 PM   #16
Signman
The thought was that reducing weight close to the center of rotation does not produce gains as would further out from center.
When thinking about flywheel weigh with large and small diameter which has more effect? On old machines have seen had large flywheels which stored energy better than smaller diameter. Those things driven by leather belts were effing dangerous started slow and slow to stop.
