Liked 216 Times in 77 Posts
If you were able to lose 100 grams off your rod/piston weight. How much ET difference would you see? I’ve looked all over trying to find an answer with no luck.
Liked 327 Times in 121 Posts
Zero.
Liked 735 Times in 386 Posts
100 grams * 8 = 800 grams / 1.7637 lbs
Let say that weight is at a 4" radius with an acceleration rate of 2500 RPS. Stan |
Liked 8,268 Times in 1,543 Posts
It sure won’t hurt …l
I have to disagree Stan. I believe the OP is referring to his LT 1 stocker and he is blueprinting the piston/rod combo to achieve the minimum weight spec set by NHRA. I dont believe he is in any danger of weakening or flexing any stocker parts…
The bulk of the weight reduction would come from a lighter rod. Production GM rod that has had small end bushed and ARP rod bolts installed vs significantly lighter Manley Rod thats on the approved list.
#8 | |
Then you should be fine. I took it as you were going to lighten the parts you had. Stan |
Liked 2,518 Times in 702 Posts
On our small block Mopars less than a hundred.
Liked 708 Times in 285 Posts
I was hoping for a better outcome. Im about 120 grams per assembly heavy. Thats basically running a ninth piston assembly
