#21 | |
Liked 2,362 Times in 559 Posts
Each to their own, but not what I want to do with the money I earn.
Daren Poole-Adams NHRA Stock/SS 2007 |
#22 |
Liked 355 Times in 80 Posts
#23 |
#24 | |
The ZL1 was not "dragstrip ready" as delivered. Do those modifications and it ran A LOT better. Add 50+ years of rule changes and it's rated only 15 HP above the factory rating. Do you have dyno numbers that you can share on that combination? It was competitive in 1969 with very few modifications and I believe it's still competitive at it's current rating?
#25 |
We talked about that, but in the end we decided not to request one.
#26 | |
2022 572 COPO 500HP FACTOR .720/.720 CAM LIFT 13.8 actual compression ratio GM 401 ALUMINUM HEADS 2.25/1.885 VALVES 340CC/130CC RUNNERS 90mm throttle body that flows 1000cfm( Rumor has it Patterson made over 1000hp with the SS version of it with same 90mm throttle body) 1969 427 430/445 HP .580/.620 lift 13.8 actual compression ratio GM 401 ALUMINUM HEADS 2.195/1.885 VALVES 320CC/120CC RUNNERS 850CFM Holley Carb |
#27 |
Liked 239 Times in 94 Posts
Chevy makes a big deal about those engines making 1000hp.... why can't it be rated at that? I'm sure with the allowable overbore and cam duration and blueprinting it should be OK. It's as legit a Stock combination as the injected 427 SOHC flip top 67 Comets are...
#28 |
For the same reason that the ZL1 wasn't rated 550 HP in 1969...
#29 |
Liked 28 Times in 15 Posts
Im new to the COPO deal i have raced stock with a c/sa 68 chevelle 396/375. I have a 2022 COPO 427 i got the car at the end of november with no place to test. I live in New Mexico so that does not give you a lot of places to go in the winter time . does any one know how fast the car should run at sea level. the way it came from the build center. I was just wondering what to expect. I know i will have to change up tune ups as i go. Thanks
#30 | |
Liked 584 Times in 94 Posts
