Old 12-18-2022, 07:30 PM   #31
Billy Nees
Liked 7,925 Times in 1,760 Posts
Default Re: NHRA hp updates
Originally Posted by mnmaxwedge View Post
That would require them to find qualified people which they surely won't do. A better solution on their part is to run Stock and Super Stock like Super Gas cars. You could only run your published index, any faster you lose. No dial unders or heads up! Wouldn't it be fun to see Stock and Super Stock cars with timers and throttle stops.
The sad part of your post is that, IMHO, NHRA is more likely to do something like that than hire qualified people. They (NHRA) really don't want the complicated rules that go along with S/SS but they don't want us to leave because there are so many of us.
Billy Nees 1188 STK, SS
Old 12-21-2022, 02:51 PM   #32
Originally Posted by Mike Gray View Post
Oh, okay I’m catching on to the new AHFS if I run BETWEEN .650 - .850 under they will like me and over .850 under and they will send me hate mail. Do I understand this correctly that my combo in B can affect other cars from AA - C because it’s in the same engine family even though the engine specs may be different, like different heads and valve sizes? I must have skimmed over the paragraph below too quickly.
“1st screening: The average for all vehicles running the particular engine family combination being reviewed is included in this screening. The review process will average runs in ALL classes TOGETHER with the same transmission type & the same body platform.”
Your combo cannot affect anything other than that same engine combo. If your combo has different heads, valve sizes, etc, then it doesn't affect combos that don't have the same specs. So, if your combo has 2.07"/1.725" valves and oval port heads, it will not affect a combo with 2.195" and 1.725" valves and rectangle ports.
Old 12-21-2022, 07:46 PM   #33
Bob Shaw
Liked 323 Times in 63 Posts
That's the way they say it works. For the 4.3 Chevy tbi engines they factor flat tappet cams, roller tappet cams, 108 wheelbase, 117 wheelbase, 430 lift cams, stock lift cams, cars or trucks together. All are considered the same engine family and body style.
Bob Shaw V/SA 515
Bob Shaw is offline   Reply With Quote
Old 12-21-2022, 10:43 PM   #34
e vassar
Liked 281 Times in 110 Posts
That would require them to find qualified people which they surely won't do. A better solution on their part is to run Stock and Super Stock like Super Gas cars. You could only run your published index, any faster you lose. No dial unders or heads up! Wouldn't it be fun to see Stock and Super Stock cars with timers and throttle stops. It would save NHRA the trouble of switching back to a full tree after the SG/SC cars run.
Yeah..I'm all for this! Just adjust my weight to run dead on the index! Hit the tree and drive the finish line.
Would sure save me a lot of money im fixin to spend. Probably have 200 stockers at divisionals.
Old 12-21-2022, 10:53 PM   #35
e vassar
Exactly!
Old 12-22-2022, 02:16 AM   #36
Mike Gray
Mike Gray's Avatar
Liked 711 Times in 205 Posts
Okay, makes more sense. Why couldn’t they just say running the same engine specs rather than “engine family”.
Mike 7570 A/SA
Old 12-23-2022, 10:49 PM   #37
Terry Cain
Terry Cain's Avatar
Liked 232 Times in 108 Posts
They wouldn't do that. They paid a law firm to write the wording.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 12-23-2022, 11:18 PM   #38
Mike Gray
Mike Gray's Avatar
The FE engine family is confusing enough with all the different variations. There are numerous combinations that could be in the same class. Now I see how this could help with the average for each because hardly any two 428 cars are running the EXACT same combinations.
Mike 7570 A/SA
Old 12-28-2022, 04:04 PM   #39
Bernhard
What effect would bringing back the factory valve spring rule have?
Would this not simplify tech and negate some of the advantage found in cylinder head and intake advancement?
Bernhard is offline   Reply With Quote
