Old 01-09-2022, 09:31 PM   #121
1347
1347's Avatar
Liked 1,032 Times in 283 Posts
Default Re: Explain to me again, please
Originally Posted by Glenn Briglio View Post
A spring rule would make the cost of going fast higher. Some people wouldn't care about that but we race a performance base class. More time on the spintron and more cams, lifters, springs, retainers, locks etc to test. But who cares about going fast. Lol
And a roller lifter rule would add more money than the 1800.00 for the tool steel ones. Most who are even having success with shubecks or even tool steel lifters would make the jump to a new roller lifter profile cam. So by the time everyone buys a couple new cams and some bushed lifters , you would be 2 or 3 thousand light in the wallet. What a great idea.
Duane Hoven
1342 SS/GT
1347 is online now   Reply With Quote
Old 01-09-2022, 11:02 PM   #122
Terry Cain
Terry Cain's Avatar
Liked 232 Times in 108 Posts
3 is a lot better than 8-10 to replace block, crank, cam, lifters, pistons, etc, etc.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 01-10-2022, 09:55 AM   #123
pmrphil
Liked 398 Times in 153 Posts
If anybody tells you that a bushed lifter won't (or can't) do the same damage with a failure, they're lying. ANY roller lifter, bearing, bushed, whatever, when it fails is going to make an expensive mess.
Phil Molski
PMR Performance
S/C 1623
Old 01-10-2022, 11:25 AM   #124
Barry Polley
Guest
Posts: n/a
NHRA will not consider this enough reason to add a h u g e expenditure to the rest of the classes. Pretty simple.
One post or poll here does not represent the rest of the country as much as some would like to think.
Old 01-10-2022, 07:55 PM   #125
SSDiv6
There are no bullet proof lifters.
I have seen all brands fail; some more than others.
Too many people believe that just bolting a specialty part is that easy and will solve all their problems. Too many times, it creates more problems.
Old 01-10-2022, 08:25 PM   #126
Todd Hoven
Guest
Posts: n/a
If you’re blowing up solids now, just think what’s going to happen with rollers. Unless you rev it higher with a cam change, you’re wasting time and money. I read somewhere where you were talking about having the same advantages cars in your class. What class do you run and what fast cars are there in that class, that have roller cams?
Old 01-10-2022, 08:48 PM   #127
john ancona
john ancona's Avatar
Liked 187 Times in 58 Posts
There you go again putting your spin ,if you have, or had a race car everyone knows everything can fail , let the poor guy alone, he like many others are only trying to come up with a solution , you have beet your drum enough , your simple minded idea that one more thing like the lifters will move stock into super stock when for years now many things have been added to make many thing more reliable in stock engines ,of with I am sure you have on your car ! I know you stated you have been against change ,but like I said before if it's such a big deal why have there been so many changes up to this point , any one or more could have sent stock into super stock !
John Ancona 717 STK / SS
john ancona is offline   Reply With Quote
Old 01-10-2022, 10:18 PM   #128
Todd Hoven
Guest
Posts: n/a
So I’m not allowed to respond? Who are you? His spokesman? A guest moderator? Did Ken hire you on? I thought this was a public forum? Let’s shift from him to you?
Do you think roller lifters will help your program? What class do you run? Do the fastest cars in your class run them?
Old 01-10-2022, 11:17 PM   #129
john ancona
As far as I am concerned feel free to say what ever you like , funny I asked the same question ,who are you to speak for others ,and tell others what to do , as you have been doing on here since 2016 , just so you know where I stand ,no I do not think roller lifters will help my program ,I sold my Camaro BBC stocker to get away from the solid lifters ,I figured my luck was running out running then for fifteen years with out a problem , also I was not the fastest to the contrary I was the slowest ! So being the slowest everybody was faster than me even the cars with roller lifters !
