Old 12-21-2020, 11:33 AM   #1
Kdw1403
Liked 68 Times in 22 Posts
Default Using blinders.
When I try to use the blinder set up I have I see the 2nd bulb inadvertently sometimes which throws me off. I sit pretty low in my car. Is there a certain set up that works better? Does Length of blinder make a difference? Do I keep both eyes open or close one eye and really focus hard through one eye. I really try hard not to move my head but the SLIGHTEST head movement makes me see the second bulb as tree comes down. Any advice from you guys? Thanks in advance. (Stocker lt1 camaro )
Kdw1403 is online now   Reply With Quote
Old 12-21-2020, 12:21 PM   #2
curtis reed
Liked 125 Times in 59 Posts
Default Re: Using blinders.
I am not able to use a blinder in my car but I wanted to say that I have used looking through one eye only to slow myself down so unless you need to kill some reaction I would use both eyes.
Curtis
curtis reed is offline   Reply With Quote
Old 12-21-2020, 12:49 PM   #3
Herbie Null
Herbie Null's Avatar
Liked 439 Times in 69 Posts
You need the blinder set up so your head is in a normal setting position, not moving your head up or down. Get the blinder adjust to see 3/4 of the third bulb and yes close your left eye in the right lane and your right eye in the left lane, this takes away of seeing any peripheral vision in the other lane. Its like trying to shoot a rifle, 1 eye closed is a lot easier to hit a target than both eyes open.
Herbie Null 201 SS
Herbie Null is offline   Reply With Quote
Old 12-21-2020, 01:59 PM   #4
thomas sheehan
thomas sheehan's Avatar
Liked 75 Times in 29 Posts
Originally Posted by Herbie Null View Post
.... yes close your left eye in the right lane and your right eye in the left lane, this takes away of seeing any peripheral vision in the other lane...
Herbie is correct about which eye to close. It may sound funny, but when using this method, if you have a big nose, you can also use it to block out the peripheral vision too.
Tom Sheehan
SS GT/NA 1046
Old 12-21-2020, 03:26 PM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,916 Times in 574 Posts
It takes a bit of seat time to get used to the blinder. You have to cover everything but the bottom yellow. Takes a lot of concentration. Unless you have a stocker that leaves hard you might not be able to hit the tree as fast as you would like. I use the bottom of the roll bar as my blinder. Just tilt my head up a bit to blind the bulbs. One other thing if you wear glasses and have bifocal or progressive lenses you might want to get a pair of single vision glasses to race with. you don't want to be looking at the tree through the reading part of the lens.
Mike Pearson 2485 SS
Old 12-22-2020, 08:28 AM   #6
jmcarter
jmcarter's Avatar
Liked 3,173 Times in 971 Posts
Surprisingly Jim or others haven’t posted this yet, top notch stuff...
https://hendersonraceshop.com/
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 12-26-2020, 07:30 PM   #7
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
What do you guys do for night races and blinders? I hear a lot of people complain about light bleeding through.
I`ve never used a blinder with a lot of night racing, so just curious.
Lane Weber
Old 12-26-2020, 10:02 PM   #8
MR DERBY CITY
Liked 7,919 Times in 1,515 Posts
I don’t know what other guys do, but when it gets dark I put my blinder on the passenger seat.....
Old 12-27-2020, 04:02 PM   #9
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Pacific Raceway runs due West and usually takes a break around sunset. I made a "blinder" in case I got caught anyway. It's just a yellow plastic sunshade hinged to my roll cage with velcro strips on it and a separate rectangle of double black painted plastic to stick to it. If I need I can stop short of staging, flip it down and position the black panel to block the sun. With some trimming it would work for the lights, too.
Dale Shearon
68 Mustang 6394
