Old 12-08-2020, 12:12 PM   #11
SSDiv6
Liked 1,575 Times in 580 Posts
Default Re: CTS trailer problem
Also, if you can, find out what type of Aluminum alloy they are using in the construction of the trailer. 2024 and 7075 Aluminum should never be welded. The heat from the welding process will cause severe cracking.
Old 12-08-2020, 01:25 PM   #12
Terry Drinkwater
Liked 22 Times in 9 Posts
What type of aluminum would be acceptable for trailers that will be welded or modified?
Thanks,
Terry
Terry Drinkwater is offline   Reply With Quote
Old 12-08-2020, 02:39 PM   #13
Willyracer
Willyracer's Avatar
Liked 57 Times in 24 Posts
Not enough weld penetration and this type of joint needs to be reinforced.
Those welds may be good for a living room table, but not for a high load structural joint.
Find a certified welding inspector and pay them a few bucks for a letter. Then have a lawyer send them a letter and attach the report with a statement that you will be also filing a report with the National Highway Traffic Safety Administration (NHTSA) for the defective welds and request a recall.
I promise you they will either fix it properly or give you a new trailer. They would not like to have the NHTSA pay them a visit, shut them down and fine them.
Thanks for the suggestion I didn't think about
getting someone like NHTSA involved
Willyracer is offline   Reply With Quote
Old 12-08-2020, 03:08 PM   #14
Terry Drinkwater
On my 2nd bumper pull camper and I've looked at lots of them. Haven't seen one yet with aluminum frame and some have fairly stout frames and tongues. (6-8 in rect. tubing) I would think most campers are lighter than your average loaded car hauler yet none are aluminum framed. Wondering about this.......
Terry
Old 12-08-2020, 04:41 PM   #15
SSDiv6
There is nothing wrong with an aluminum trailer as long it is designed properly and the right materials are used. Most tanker trailers have aluminum frames.
The aluminum alloy to use is 6061-T6 extrusions, not 2024 or 7075. To weld 6061-T6 you need a 5356 filler and 6061 will recover after welding. High end aluminum trailer frames built from 6061 aluminum are joined together just like an aircraft frame with Huckbolt fasteners and there is minimal welding.
By the way, Huckbolt fasteners are as strong as welding.
https://applifast.com/wp-content/upl...vs-Welding.pdf
Old 12-08-2020, 04:43 PM   #16
SSDiv6
Originally Posted by terry drinkwater View Post
what type of aluminum would be acceptable for trailers that will be welded or modified?
Thanks, terry
6061-t6
Old 12-08-2020, 04:48 PM   #17
Race Clean
Liked 129 Times in 53 Posts
Aluminum welded together in high stress areas is not the best option!
Stop global whining
Race Clean is offline   Reply With Quote
Old 12-08-2020, 10:34 PM   #18
Markeracer
Liked 67 Times in 28 Posts
Willyracer, please post full company name of CTS, location and website so we are all aware. Thanks
Markeracer is offline   Reply With Quote
Old 12-08-2020, 10:47 PM   #19
Willyracer
Willyracer's Avatar
Custom Trailer Solutions
Could be wrong but thought ATC was manufatured at the
same location in north Indiana
Sorry
Don't know their web site
Old 12-09-2020, 12:11 AM   #20
SSDiv6
CTS Trailers LLC
312 S. 4th St., Suite 700
Louisville, KY 40202
Their website does not work:
http://www.mycustomtrailer.com/
The owner of CTS used to work for Millennium Trailers as a salesman and had created CTS behind their back and was taking customers away from Millennium.
Read the document in the link below. I do not think you have a chance to get it repaired by CTS. Your best bet would be a lawyer and NHTSA.
https://cases.justia.com/indiana/cou...?ts=1444316901
