#11 |
Liked 25 Times in 9 Posts
not mine, in my sports car club so i can check it out for you. already caged. https://www.facebook.com/commerce/li...are_attachment
asking $2K
Jeff Laferty Suffolk, VA |
#12 | |
Liked 5,153 Times in 1,967 Posts
Maybe I should mention, I need the Ford 1.9 engine. That one has the Mazda 1.8, on which there are no engine specs
#13 |
Liked 336 Times in 183 Posts
Mark --check your PM --Dick
#14 |
Liked 314 Times in 113 Posts
Mark,
I'm curious about a couple of things if you don't mind answering some questions about this build. 1. Do you get out the die grinder and turn the transmission into a crash box, or do you have another method of achieving quick consistent shifts? 2. Given the distance from the shifter to the transmission, what do you use for a shifter and linkage that does nor deflect or bend under the pressure of competition?
Larry Merk |
#15 | |
The first problem is not going into 5th instead of 3rd. I'll make a slotted gate, where you can still grab reverse in a hurry. The 82 used stock gearboxes from the boneyard,...stock shifter too. I normally use a T handle on regular stuff. I didn't want to be able to pull on it that hard. You have to shift FWD's differently than you would with a Super Shifter. More like driving the stock factory shifters in the 60's. Never missed one with the 82, so we'll see. Update : We found three cars on Offerup , in SoCal. 1, says he still has it but doesn't seem to want to converse in English. 2 and 3, No response..Ads have been up for months, and possibly not cancelled. They could be in The Big House by now, for all I know. I do know that O/U is just as bad as F/B. We'll keep tryin' . Thanks
#16 |
I get to So Cal a couple times a week or more = Let me know
if you need something inspected or even transported!
#17 |
Thanks C/R and everybody who tried to help out.
I found one, and I started a build thread, if you're really bored MY
