#192 |
Liked 800 Times in 237 Posts
Be a couple days before we're at that point.
"That'll never work....." |
#193 |
Liked 373 Times in 129 Posts
Whats a good flow number for a 1.940 fuelie stocker head @ .400 lift? Anyone.......
#194 |
Got the cam broken in and valve springs changed. Made some preliminary pulls and moved the cam around. We'll get back to it after the Phoenix National event. -Al
#195 |
Liked 985 Times in 314 Posts
Tease......
#196 |
Liked 73 Times in 36 Posts
Alan and others,
Can't tell from the pic, but if the odd number side plug wires are similarly bunched......it would be better to be sure that 5 and 7 DO NOT run parallel and bunched together (should be separated at least a couple of inches). An odd thing called inductive coupling occurs and can encourage cross firing and you would not hear it but power would suffer a bit. ![]() ![]() ![]() Regards, HB2 ![]() Dissident |
#197 | |
#198 |
Finished up by testing four different fuels. Time for it to go in the car and get ready for the season.
I can't thank Bob Sherwood enough. It's his dyno that I'm fortunate to test on. His experience in not only dyno operation but data interpretation have been invaluable. Bob is truly one of the good guys. Thank you, Bob!
#199 |
Liked 240 Times in 112 Posts
Dave Noll, EF/S ,?/SA 6526 |
#200 |
Cal Elston does beautiful work. Smart, smart guy.
